Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
HOSE PARTS? WHERE DO I GET THE PARTS FOR MY WASHER. SO I CAN HAVE WATER COME IN AND WATER DRAIN OUT.
  • 550 Answers
If you mean external hoses between tap and washing machine, and washing machine and waste drain to install the washer in place. Everywhere. even the local hardware store, those items are a standard size, thread, and diameter and fit all washers.
if you mean the click fit hose to a sink tap, with the waste water drain buldled in so the washer can remain portable
Sears has them as a to-order item and most parts stores will have a generic brand that will fit straight on, the screw fittings are standard.
Posted on Sep 01, 2008
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
Hose leak connection drain hose to washer
Seems peculiar to me there's so much pressure on a drain hose. Are you pumping to a drain much higher than the top of the washer?
Just pumping water out of a drain hose shouldn't create much pressure unless the hose is kinked or restricted. Look for that problem first. You could get a hose clamp from an auto parts store that's much more reliable than the spring clamps you're describing. I would try that on the inside and outside connection and see if it solves the problem.
Aug 02, 2017 | Haier HLP21N Washer
Drain stand pipe Washer fills and drains at same time. Manual says the drain stand pipe must be greater than 30 degrees. I would like to have a description of the drain stand pipe and it's...
30 degrees or 30 inches. The drain stand pipe is separate from the washer and usual plumbed in behind the washer. You bring the the drain hose up to the top of the standpipe and then push the end (forming an upside down U at this point) into the top of the open 2-3" diameter PVC pipe and secure it so that it won't back out (but do not seal the opening). Nylon ties or hose clamps will work. The height requirement is so that the bottom of the hose in the standpipe is above the water level in the washer - this avoids the drain siphoning the water out of the washer. Check how far into the standpipe the drain hose has been pushed. If it is below the level of the water in the washer, back it out. Check the height of the standpipe. Many washer manuals recommend a 34" standpipe (max height of 48") based on the drain hose length on the down side of the U. Also make sure no one sealed the top of the standpipe against air entering the pipe. (Often this is done because of a back up in the drain, pull the drain hose out and get the pipe cleaned out and then put the hose in to the proper distance. Then leave the top of the standpipe open.)
For a picture of the standpipe, see http://www.appliance411.com/faq/washer-drain.shtml .
There is a parts diagram for your washer itself is here: http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-GLWN5050M0WS/0432/0153200?searchedModel=glwn5050&blt= .
I hope this helps.
Feb 28, 2011 | Washing Machines
Won't fillCalypso whirlpool washer model#GVW9959KQ1 LD on display
LD is long drain error, the machine does not fill because it is in fault mode, but error is on drain system.
If there is a drain problem, the parts that must be checked are drain hose, pressure switch, drain pump assembly, timer control.
Check if the drain hose at the back is kinked or blocked.
Test the pressure switch, blow into the small hose, and use a multimeter to check if switch has continuity.
Remove access panel and get to the drain pump hose to check for ablockage. You will need to disconnect the hose and collect the water.
Keep a container ready to collect water when you undo pump hose.
Ifall the rest is OK, test and eventually replace timer board.Problemwith water pump are far more commonly causing this problemsthenfaulty timer board.
Parts and diagrams available here.
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The water is entering the washer, but is not
Either the drain hose is too far into the drain or drain hose is too tight in the drain . Make sure the drain hose is NOT taped to the drain (to keep the drain pipe from overflowing ) All of these will cause a syphon problem , where water will be "pulled out" of the machine by your sewer line , as water is filling your machine for wash (usually rinse cycle).
Sep 10, 2009 | Kenmore Elite 45986 Front Load Washer
Water continuously runs and cycle won't start. The washer tub doesn't seem to be filling with any water.
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
Aug 08, 2009 | GE WVSR1060A Top Load Washer
My washer wont drain
The washer's pump unit has stopped working. It may not me getting the signal to pump after the wash cycle (controller problem) or the pump has let go and needs to be replaced.
Aug 04, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer is not draining during the spin cycle
not draining your washer at all, pump may be bad or no power to pump, take the drain hose out of the "stand-pipe" where water enters the sewer drain, and lower to floor and see if water drains by gravity if only slowly your pump or hose may have a slug of crud in it blocking drainage to sewer pipe
Aug 02, 2009 | GE WJSR4160DWW Top Load Washer
FTW445ges2 Washer won't drain, buzzes during drain cycle
Hi...
You need to check this parts.
Inspect the drain hose for kinks
Test the timer control
Test the lid switch(some models)
Inspect the water pump
Inspect the driver belt(belt drive only)
Inspect the motor coupler
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope it will help you.
Regards
ICmanServer
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Not draining?
something is stuck under the auger,causing restriction. Whatever is stuck, its blocking the drain.
Jan 22, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
73 people viewed this question
Sal De
fordexpert
Robert Rankin
