Question about Malber P25 Front Load Washer
Rubber piece i noticed that there is a hole in the rubber piece on my front load washer. can i tape it up or do i need to replace the entire rubber piece.
  • kenp198 Nov 18, 2008
    My P16 has the same hole at the bottom of the grey rubber sealant ring. It is a drain hole for any water that gets between the inner and outer lips. It should be there - at least it should be there on my P16.
    Is water draining out onto the floor? What happens if you run the unit? does it wash? Does it empty it's wash waterwhile washing? If so then the problem is not with the hole in the rubber ring.
  • saslats May 11, 2010
    Do you mean in the bottom of the rubber gasket between the door and the drum? If so, it is supposed to be there so that it won't hold water when cycle is finished. This prevents dirty water from staying in the gasket and smelling.
If you mean in the bottom of the gasket between the drum and the door the hole is to allow water to drain from the gasket to prevent standing water which will smell .
Posted on Sep 04, 2009
Machine leaks water
The most common place for a front load washer to leak is in the bellow. This is the rubber piece right inside the door. Pull the rubber piece back and check for tears or holes. If there are not any holes then there is probably a hole in the hose that runs from the tub to the pump. Sometimes stupid things like bra underwire and bobbi pins get in here and tear them
Aug 25, 2012 | Maytag MHWZ400T Front Load Washer
We have water leaking out of the front of our washer not from the door but from just below the door. Is all over the floor??
most likely you have a hole in the boot seal,the rubber piece in between the door and the tub,also open the door and wipe the bottom part of the door on the plastic window,i've found pieces of hair there and the water travels down the hair and leaks through the door.if that's clean you have a hole in the boot seal,open the door,spread the rubber boot open and with you fingers feel all around the rubber boot
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Frigidaire front load washer (GLTF1040ASO) is leaking water by the detergent dispenser area. Any suggestions on what this could be?
This is usually caused by solidified detergent blocking the water ways in the detergent dispenser.
Check the inside of the dispenser to make sure the outlet holes are not blocked.
Most dispensers can be removed for cleaning check your appliance instructions for details.
Dec 13, 2010 | Frigidaire GLTF1040A Front Load Washer
The door handle has broken off and a piece of the door where the screws for the handle go is broken. Right now, the only way to use the washer is by taping the door shut. Is it possible to replace the...
from your description It seems to me you need frame #8182628 and handle #8181846.
the door comes as separate parts, not an assembly, but they are pretty straightforward to put together
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am finding tiny holes in the sleeves and fronts of random cotton shirts. i had an exterminator in and he could not find one bug in my entire house. is it possible it is washer or dryer related? it's...
Check for any small pieces of sharp metal in your washer tub on the front and back where the tub has a seam and is welded together. (you will need a flashlight and will have to put your head inside the washer to see this.) Check very carefully it could be very small. I have seen the stray metal welded into the tub and the tub would have to be replaced. Also check your dryer for anything sharp or holes in the front and back seals. Please rate this post.
Dec 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew smell
PLEASE KKEP IN MIND THAT THE MAYTAG NEPRUNE FRONT LOAD WASHER IS WHAT GOT MAYTAG IN TROUBLE!!!!!!
Whirlpool bought MAYTAG about 3 year ago.
THe mold is because of the rubber boot in the front of the door. PLEASE check to see if the rubber seal has a small hole in the lower bottom of the seal to let small portions of water drain out. If you DO NOT have this small hole, you need to replace the rubber boot with one that has a hole.
NOW, WORD TO THE WISE and this is what I tell ALL FOLKS that have a FRONTLOAD WASHING MACHINE:
AFTER you washer in the washer LEAVE THE DOOR OPEN so that the washer can ventilate and remove any moisture that is within.
ALSO, every 2 months, get a WHITE CLOTH with WARM WATER and a littl;e bit of BLEACH and CLEAN THE RUBBER BOOT!!!!!!
Nov 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Malber P25 Front Load Washer Logo
174 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
