Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
No cooling freezer ok but fridge not cooling
  • 3 more comments
  • Anonymous Aug 11, 2008
    I removed the trays at the bottom to access the fans on the refrigerator side. I then pressed the door switch expecting the fans to run but none of the three fans ran. I unplugged the wire harnesses from the fans to measure the DC voltage. I thought I saw the rated voltage coming of the harness. I am not sure about this since the voltage seemed inconsistent and I am not used to measuring DC voltages. In the meantime, the coil on the refrigerator side continued to get cold. Could this be the main board problem or what, since I don't think all the 3 fans are all bad?
    hhfgh
    gsg
    I pressed the door switch on the refrigerator side but none of the three fans ran. The freezer fan runs and cools ok. Could it be the main board problem or what, coz I don't believe all the fans could be bad? Thanks in advance.
    James
  • twer Aug 11, 2008
    James
  • 828 Answers
Both refrigerator and freezer operate from one system. Air from freezer cools refrigerator. Check back wall of freezer for frost buildup. If frost is evident on the back wall of the freezer it indicates a defrost system problem.
Posted on Aug 09, 2008
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Got a hotpoint ff72 fridge freezer and the fridge is not working, light still comes on but fridge is warm. freezer is ok
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 14, 2011 | Hotpoint Refrigerators
Amica Fridge Freezer A K 215. Freezer ok but fridge not getting cold
heatman101
May 09, 2011 | Refrigerators
Candy fridge freezer seems 2 be running ok.....but freezer only does -minus 10...fridge plus 14.....back of item is nice and clean.......?
heatman101
Apr 17, 2011 | Candy CPDA241 Top Freezer Refrigerator
Freezer ok fridge not cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 07, 2011 | Daewoo FRSU20IA Freezer
In my candy fridge freezer the freezer is working ok but the fridge isn't working at all. Please advise
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 31, 2010 | Candy CPCA240FFK Bottom Freezer...
Freezer ok fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
wHGJ
May 23, 2010 | Frigidaire FRT21P5A Top Freezer...
Greetings! My Whirlpool 21 is not cooling on the bottom, but the fridge is OK. Art
I do not understand your question because your note says it is a top freezer, but the fridge is ok?
The bottom section IS the fridge on this type.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
216 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
