Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Anyway to increase screen res. while using pc?
The manual states that the max res. it can accept from a pc is 1024x728, I was wondering if there is something I can purchase that will allow me to display a much higher res.
I want to purchase a new video card and thought there may be something out that that will convert the res to a an acceptable HD format that the tv can recognize if that makes sense.
  • jeproha Aug 23, 2008
    Thanks.
  • 44 Answers
No, no way to change. The imager in the unit is the physical and electronic limitation. To change that would require all new supporting electronics and optics.
Posted on Aug 22, 2008
Can not read items in google search print too small
Click on view, tect size, thoose you from the list.
or,
your desktop is set to a high res. right click on desktop, prop, settings, choose a lower screen res. ( note this will also increase your icon size)
Dec 31, 2010 | Toshiba Satellite P35-S611 Notebook
When i try to change to res it says out of range. it stays at 800 x 600.
Max Sync Rate (V x H) 76 Hz x 83 KHz
Max Resolution 1280 x 1024 / 60 Hz
Try changing the Hz to get it to accept a higher res.
Dec 02, 2010 | HP vp17 Monitor
I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
Please rate this reply - good luck!
Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
Dynex 19 LCD
I went over the specs of the TV.
The max input for the VGA is 1360x768 at 60Hz. Anything higher will make the TV go bonkers.
I would try to get the resolution at 1360x768, then change the frequency to 60Hz.
May 29, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Acer Travelmate 529atxv states max memory as 512mb
512mb is the max memory amount this computer will accept.
Each memory slot can hold SDRAM, PC133 with a maximum of 256MB per slot. Two slots total. Hope this helps.
Mar 07, 2009 | Acer TravelMate 529ATX Notebook
4gb ram wont work
its not XP it will be the maximum capabilities of the amount of memory the laptop can handle, please refer to manual for max amount, i would suspect 2GB max
Aug 19, 2008 | HP Compaq 6720s Notebook
Monitor dark
I had a similar problem with this monitor, mine was dim all the time to the point you cant use it, but the MENU icon was bright as new... also if cable was unplugged the box would float around as normal.... anyway I fixed it by taking it all apart and pushing in the socketed chip.. it clicked like it moved, I also pushed on the variable resistors on the power supply... now it works!!! First time since it quite working long time ago
May 29, 2007 | Samsung SyncMaster 175V 17" LCD Monitor
Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Apr 14, 2007 | LG 42PX5D 42 in. Plasma HDTV
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
