Question about Casio QT 6000 Point of Sale Terminal
Qt-6000 the screen shows an an error-E011 close the drawer. but the drawer is closed. I don't have the key to open it again. What can I do?
I have same this problem! Who can help me??? Thanks
Posted on Sep 21, 2008
Unlock Toshiba DVD player SDP93S bought in America to play Australian DVD's
Thanks for understanding. Please let me know if you require any clarifications.
Jul 09, 2011 | Toshiba SDP93S Portable DVD Player
I have a Minolta CSPro 4000, and I am getting the following errors on the display screen code 0d50
C0d50 means you have a duplex error. This would be coming from the duplex drawer just under the main front door. You must open then close the duplex drawer to reset this code. It can not be reset by opening/closing the front door as with most other codes. Most of the time the c0d50 code will reset by opening/closing the duplex drawer. If not you will need service on the drawer as there is a drive or sensor problem in the drawer. The guides in this drawer have to jog in and out for different paper sizes and orientations. This code is usually causes by a failure of the guides to move properly.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
Its a casio ce 6100 cash register ad the memory seems to have gone, now when i press the clerk key E011 appears on the screen
You have to close the cash drawer to make a sale. E11 means drawer open while sale in progress. If that doesn't fix it, check the wiring to the drawer, especially the brown wire. -------------------------------------------------------------------------------------------------------
For anyone needing a Casio CE-6100 manual, go here: http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Jun 04, 2010 | Casio Parts Cash Register PC Desktop
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Change screen saver picture
The QT-6100 screen saver is the same as the QT-6000. Allocate the screen logo in Scanning System. Create a bitmap image that is 800x600 and send it to the QT using CV-31. Flag clear the terminal and set the option in Display Control to show the logo at clerk sign off.
www.casiohelp.com
May 11, 2009 | Casio QT 6000 Point of Sale Terminal
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
Frigidare front load washer error code
Could be "detergent drawer open". Try opening and closing the door shut. There is a magnet there which shows that the door is closed or open. Use front loading washing powders preferably.
Nov 29, 2007 | Washing Machines
Casio QT 6000 Point of Sale Terminal Logo
141 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
