Question about GE (PSS26MSRSS) Side by Side Refrigerator
Side by side GE refrigerator psf26pgta
Freezer cooling ok but refrigerator side not cooling. Removed trays and accessed the coils and 3 fans on refrigerator side. Pushed door switch but fans did not run. Could see coil getting cold. Fridge seems all electronic. Main Board no. WR49X10121
  • donnied65 Aug 28, 2008
    the freezer working fine. refridgerator side not getting cold.
  • 74 Answers
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
Posted on Aug 28, 2008
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge side by side not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
hghj
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Will not dispense ice through the door
Take ice tray out of freezer .Empty ice and see if your cool is jammed in there. My coil went off track
Feb 14, 2009 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
Psf26pgta
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Aug 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator cools, but no freezer fan & no condensor fan running
Check the back of you fridge and make sure the coils are clean. If you have access to a small air compressor, blow everything out and make sure the motor are is clean. The build up of dirt on the coils will not let the heat escape during the cooling process.
Mar 04, 2008 | Jenn-Air JCD2389G Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
317 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
