Question about Vitamix Super 5000 Work Top Blender
I'm starting a sport and I cant figur out if i should take vitamins to keep me heathy?
  • Corey Knoettgen
    Corey Knoettgen May 11, 2010
    I think it's great that you are starting a sport. I ran track and cross-country for several years. I did it without the aid of vitamins, but I wasn't exactly a world-class athlete either. I only send this advice to you, because this is largely a technically-oriented website of volunteers, and we are not (to my knowledge) qualified medical doctors: only a qualified medical doctor or physician can really give you sound advice as to whether you should take vitamins or not. Some people can have unforeseen reactions to anything, even vitamins, so it is best to consult with a doctor. Your coach can possibly lead you in the right direction. I only say this so that you don't receive bad advice from an unqualified poster or marketer. Good luck with the search.
    President:
  • 846 Answers
As ThaMp3Doctor said this is a Tech savy website. I think you wanted WebMD not Fixya below is the link to a proper site to find more information on multi vitamins and health.
http://www.webmd.com
Enjoy and good luck. Thank you for trying Fixya!
Posted on Mar 22, 2009
Replaced Capacitor and resistors motor running fine but cant keep the belt on keeps running off should rotation be clock or anti clock
Generally speaking, belt tracking issues are usually due to one or more of the shafts that support the pulleys not being perpendicular to each other - this applies to everything from treadmills to fan belts. Check and correct if possible: that the motor is securely mounted in the housing and that it is not installed crooked; and that the shafts aren't loose or have sloppy side to side movement. Belts should be tight - but not overly so.
Jul 22, 2015 | Kenwood Chef A901 901p 907 Quality Motor...
Can't unscrew drive socket on vitamin super 5000 yo replace it
The hex wrench only fits in one position, there is a groove in the lip in the top housing and you need to turn the coupling until the hex screw head lines up. The groove is normally plugged with a dob of white silicone. The hex screw is not tightened fully tight on reassembly, the coupling needs a bit of slop.
Aug 23, 2013 | Vitamix 5000 Work Top Blender
Vitamin 3600 canister leak
I think it's the little washer in the blade assmbly since mine was worn to a sliver when it started doing what yours did. I replaced it with a similar washer and it worked for a week and then started spitting out metallic dust until it stopped working again. Could be the bearing seized. I would say yes a new blade assembly but I hadn't found one- since I have a 3600 which is very old-when my husband bought a used replacement container with a working blade assembly on ebay. $37 bucks, problem solved.
Mar 28, 2012 | Vitamix Blenders
I have a kenmore refrigerator Model 363.9771612. It has an ice cube maker but that is not hooked up. I keep finding water on the floor of the refrigerator and I cannot figure where the water is coming...
on some models there is a condensation pan...is it still in place?
look up the manual & see if it shows a collection tray?"
usually a hose just above the tray to direct condensate into the pan?
Nov 15, 2010 | Kenmore Blenders
Waring blender - new blade
You can call Waring and they can send you a parts breakdown showing the order the parts need to be in. If you still have problems they can go over the assembly with you on the phone or direct you to a service center near you to help.
Feb 21, 2009 | Blenders
I have a K-TEC HP3 blender (2004 model). The jar started leaking bellow the blade. I tried to take out the blade and seal out, could not figure out how to. Any help is appreciated.
Usualy there is a rubber ring araound the bottom of the blade. If it gets worn out or out of posistion it may start to leak. Also if you dont have everything screwed in tight enought it could leak as well
Jan 01, 2009 | K-Tec Champ HP3 Work Top Blender
Health master 100 jammed gears in blender container
no but figures you dont actually give free help.....its all about the almighty dollar..
Peace
Nov 11, 2008 | Jack Lalanne Health Master 100 8-Speed...
Lights/LED lit up, but blender does not start!
The motor brushes may be in need of replacement.
Sep 09, 2017 | Cuisinart CB-600 Blender
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Vitamix Super 5000 Work Top Blender Logo
720 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
