Question about Canon PIXMA MP160 All-In-One InkJet Printer
Occasional streak in a line of text.
On printed page, some lines of text are streaked with blanks. Example:
  • saintjust Aug 08, 2008
    Thanks for your help, techexpert12.
    New cartridges did the trick.
    4 stars for the prompt resolution !
    Saint Just
    Master:
  • 521 Answers
Cartridge would me nearly empty or the printhead is blocked remove and try to clean gently if no difference then servicing is required.
Posted on Aug 08, 2008
SOURCE:
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Streaks or lines
Vertical streaks:
Check,which color/s streaks are appearing on print out,remove that cartridge/s check on drum surface for streaks.. if found replace that cartridge/s..check.
Horizontal streaks:
This problem appears when the cartridge/s image drum not rotating properly. Resit the cartridges properly, print 20nos of blank pages, then check.... replace the cartridge..
Dec 29, 2012 | HP Color LaserJet 2600n Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
It prints vertical lines where the text is.
check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Feb 27, 2009 | Dell 946 All-In-One InkJet Printer
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Epson CX3810 started leaving blank streaks, now no ink on page
I went to Epson.com's technology on google - and as I followed their prompts, I learned that it was the printer heads and that you aren't supposed to tilt the machine. I have been moving it a lot, so undoubtedly tilted it. You can follow the prompts after a right click on the printer icon on the bottom left corner of the monitor and it cleans the printer head. This also solves a white streak problem if people are having white streaks where there's no pringint....They had lost of answers there too.
Dec 13, 2008 | Epson Stylus CX3810 All-In-One InkJet...
Magicolor 2530 DL
The streaks are typically a sign of a toner drum going bad, or possibly just dirty, or even caused by the toner being low, as you have mentioned it to be. 1 way I know to 'clean' the drums is to have the printer run multiple blank pages. If your software will not allow you to print blank pages, type a single character by using this little trick, hold down the ALT key, and type 2 5 5 on the number pad in a blank text document. This will allow you to print the "blank" document, I would suggest about 10 copies. This should help for a short duration, and doesn't use any toner.
Hope this helps!
Backu
Oct 30, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Prints black vertical line at bottom of page on every print. HP 8550gn
This should help -
Developer streak
Developer streak is characterized by a line of dark or missing toner
that stretches from the leading edge to the trailing edge. Replace the
toner cartridge corresponding to the color of the developer streak (for
example, if the streak is magenta, replace the magenta toner
cartridge).
Repetitive defects troubleshooting
Repetitive defects are defects that occur in the same vertical position
on the page, but not necessarily on every page. Most repetitive
defects are caused by problems with one of the following, and are
indicated by the positioning of the defect on the page:
 developer roller (at 38 mm)
 charging roller (at 44 mm)—see additional information under
“Charge roller set” on page 454.
 cleaning roller (at 56 mm)
 developer DSD wheels (at 65 mm)
 transfer roller (at 66 mm)
 transfer drum (occurs once per 11-by-17 inch or A3-sized page,
or every other letter- or A4-sized page)
 fuser (at 150.5 mm)
 imaging drum (at 195 mm)
 transfer belt (at 222 mm)
May 21, 2008 | Office Equipment & Supplies
Streaking
Hi there it will be either the drum unit for the color streaks you are getting or the fuser unit. Check the drum units for the streaks on them also check the fuser but the clue is when you have the streaks in different places. Most likely to be the drum units. You will need to replace.
Thanks J
Oct 30, 2007 | Ricoh Aficio CL7000 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
125 people viewed this question
Clive
Clive
old marine
old marine
Ekse
