Question about Whirlpool Washing Machines
I am trying to take the drain pump off of my washer and it seems to be stuck. how do i get it off?
  • carchie04 Aug 08, 2008
    It is a whirlpool top load model # LBR5232EQ0
  • Mike Durland
    Mike Durland May 11, 2010
    what kind of washer is it?
  • 481 Answers
The motor shaft is rusted causing the plastic pump to be stuck. you might have to cut thru the center of the pump with a chisel or flat screwdriver. once you get the pump off then you will have to grind the motor shaft down a little before installing a new pump. if the new pump doesnt just slide on and off easily then dont force it.
  • cut the center of the water pump where you see the red circle. cut all the way to the motor shaft.
Posted on Aug 08, 2008
SOURCE:
Wont turn off/stuck in drain mode
This sounds like a washer and not a dishwasher. The rubber you are referring to is the door gasket and it needs to be replaced in your case. It has got into the pump and it's plugging it. Please remove any debris from the pump and start the unit again.
Mar 11, 2014 | Dishwashers
Programs don't advance. The machine seems stuck in each mode, it will fill and wash but doesn't advance through the programs. I have to switch off and manually advance the dial to rinse, spin, drain etc
Try moving your drain hose to a different height.t may need lower than you have it. My washer did the same , Drain hose needs to be higher than the pump that drains the washer.
Aug 09, 2013 | Indesit W 123 Front Load Washer
Washer stopped draining
Something like a sock or small rag is stuck in Pump. That will have to be removed if possible or replace Pump.
Nov 14, 2017 | GE WJSR2070B Top Load Washer
Washer stopped during spin cycle
Hello, try to checked the pump filter, and the pump is actually working. then I would suspect a draining problem.
If filter clean and pump works fine then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Thanks
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
Kenmore front-loader washer doesn't drain all the time. Seems pretty random. Took off the front cover and checked the filter basket several times - didn't see any evidence of blockage in the pump. When...
If your washer won't drain, check these:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 29, 2010 | Kenmore HE3T Washer
Washer does not seem to drain. There is a rattling noise that sounds as if something is loose in the load.
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
MY MACHINE HAS STOPPED DRAINING
Good Luck!!
Mar 22, 2009 | Washing Machines
Spacemaker spin cycle problem
you may have something stuck in the drain pump......
first try using a wet/dry vacuum attach it to the drain hose and try to **** out what ever you have stuck in there... if that works you are good... if not you will have to get open the cabinet to get to the drain pump
Dec 23, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
My washer/dryer is not draining properly.
If the pump is not draining, either the drain filter screen is clogged with debris, the drain pump is jammed by foreign debris or the drain pump itself has failed.  More than likely something is clogged in the filter screen or a sock is jammed up inside the drain bellows tube just before the filter.  Pull the drain filter screen out and look up the hole to see if there is any material stuck inside.  Usually that's the problem.
Nov 19, 2007 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
