Question about Harley Davidson Road Tech HA90 MP3 Player
1998 ultra classic
Cruise quit. brakelight stays on!
  • 3 Answers
Check brake switch by rear master cylinder
Either the switch is bad or the wire came off
Posted on Aug 16, 2008
Cruise control does not activate when turned on,brakelights work pedal is not stuck on.when starting vehicle instrument cluster illuminates speed control lamp
Brake lights are not an indication that the cruise control works. The brake light switch and the cruise control switch are usually 2 different switches. Physically inspect the brake pedal shaft.
Sep 23, 2015 | Cars & Trucks
2007 Caravan SXT..Cruise quit functioning..Press cruise and the green cruise light comes on in the dash but flickers..Any ideas appreciated. Horn does work. No obvious brakelight issues.
Look on the panel that covered the fuse box that you removed to get to the fuses. There will be a picture with corresponding numbers to as to which fuse controls what and what number it is.
Does that help out ?
Apr 26, 2015 | 2007 Dodge Grand Caravan SXT Minivan
1979 gmc truck van no brakelights
Check your blinker switch in the steering column. I had an old Ford Galaxy that the brake lights quit working on and it turned out to be that.
Jul 13, 2014 | E92 Halogen Brakelight/Stoplight Kit for...
When I step on the brake the cruise control will not disengage
There are 2 switches at the brake pedal. 1 is the brakelight switch & the other is the cruise disengage switch. Possibly 2 faulty switches but you should diagnose first. Check brake light fuse, then disconect brakelight switch, bridge plug brakelight switch if lights come on = faulty switch, check globes
Jul 14, 2012 | 1988 Ford Mustang
Brakelights stay on
the brakelights stay on cause you have a bad brakelight switch.
Jun 27, 2011 | 1997 Pontiac Grand Prix
Can a brakelight switch for no cruise control be used instead of one with cruise control?
No, the wiring would not be the same because the brake light switch is what turns off your cruise control when you step on the brake.
Feb 22, 2011 | 1992 Toyota Camry V6
2004 Pontiac Montana Brake Lights, Pwr Window and Cruise all Quit
The same thing happened to my 2002 Montana minus the power window problem.
The brake lights and the cruise control are somehow tied in together.
I went to the scrapyard and ripped off a couple circuit boards from an old Lumina ($25 for the set) since there were no Montanas on site.
The problem seems to be when one brakelight goes the bulk of the current transfers to the other light and will blow it too.
Anyways you said you tried replacing the circuit boards and it did not work so sorry I could not be of more help.
Jul 23, 2009 | 2003 Pontiac Montana
2000 Sunfire cruise control not working?fuse and cable good??
There was a factory recall for the cruise control back in 2003, I would look into that first.
Dec 20, 2008 | 2002 Pontiac Sunfire
Cruise quit. brakelight stays on! on 1998 ultra classic
This is going to be a problem with one of the brake switches, most likely the switch on the front brake lever. The switch generally has slipped out a bit and needs readjusting, or corroded slightly on the inside and needs cleaned and lubed. What's happening is the brake switch is on, as if the brakes were applied, and the cruise's automatic disengage function when the brakes are applied is kicking in and not allowing the cruise to work.
Aug 08, 2008 | Harley Davidson Road Tech HA90 MP3 Player
Open Questions:
See all Harley Davidson Road Tech HA90 MP3 Player Questions
Harley Davidson Road Tech HA90 MP3 Player Logo
59 people viewed this question
Top Harley Davidson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Harley Davidson Audio Player and Recorder Expert? Answer questions, earn points and help others
