When i turn my tv on the temp and lamp flashes red and it dont show no picture
  • 8,617 Answers
Whats the model number of your set? Please respond to this same post and I will help you with the problem.
Posted on Aug 08, 2008
SOURCE:
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Jan 09, 2016 | Samsung Televison & Video
Sony kdf e50a10 no picture 4 red led flashes
Made around 2005---It should have a rather large fan at the lamp---there is a thermal sensor there that looks somewhat like a temp sending unit in a auto----there is also in the wire harness a thermal fuse but that is good based on your blink code.
I would not alter the design of the fans but make sure they are not that dirty--they will slow down if dirty.
My focus would be on either the sensor for temp for the lamp being bad or the fan there being bad---both are possible.
May 28, 2012 | Sony Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Hitachi model number 50V720 does not show picture or sound when turned on. The Temp light and the lamp light flash red on and off. What's the problem?
Check the tv fan it is running?No than the fan require replacing.Yes,than the tv projection lamp life are ending require replacing.
Apr 14, 2011 | Hitachi 50V500 50 in. HD-Ready LCD...
TV won't turn on - no picture or sound -and the 3rd of the 3 LED lights on front of TV is flashing red
HI, this is a failed power supply board. simply replacing the failed power board will fix this issue.
Jun 18, 2009 | LG RU-52SZ30 52" Rear Projection...
Tv turns off tne comes back on
Please count red light flash again.
5 times flash shows Lamp Error.
6 times flash shows No "DD 6V " output (G1 board) Its bit technical term.
Need fuhrer help, please Post it here.
Thank you.
Sep 21, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Hitachi T.V.
Good Day, halobeast044;
Replaced the LAMP. Good Luck big IRISH.
Jul 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
No picture
Symptom: LAMP Led Blinking Cause: Check the door lamp switch & lamp pwr switch, boss on the door or lamp assy may not close switch. apply tape to boss.
May 13, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Ekse
