Hi syarief03120,
Actually you can manually remove the paper from the printer. It can be pulled out from the feed area.
And to clear the paper jam message: You have to take the back cover off, there is a reset switch in the top left hand
lock hole. Use an object to push in the pin hole. After that put back the cover on. This should help you fix the problem.
Hope it helps.
Thank you for using Fixya.
SOURCE: can i download the installer of HP Deskjet 1280
you can go to the hp.com website and download the drivers from there
SOURCE: paper jam in hp deskjet d2560
Most printers have an access panel located in the back of the printer that will allow access for removal of all of the paper. Remove any larger pieces by pulling slowly and gently on the paper.
SOURCE: paper jam in HP deskjet 380 series
I just completely took apart my front feeder unit because I just didn't believe there was a paper stuck in there. Sure enough, when I got to the bottom (an hour later) there it was- and it wasn't from the paper that was jammed. It must have been floating around in there waiting to get in just the right place to block the little sensor wiggly thing.
After I got it out, I realized there was a MUCH easier solution--- get some heavy paper (I used cardboard folded in half) and manually feed it through the paper feeder in the front assembly by hand. You can see where it should go in (it's where the paper from Tray 1 goes in) and out (it lines up with the belt in the main body of the printer) and there is a large gear on the side you can turn to help you get it through (just turn the gears until you feel the one that grabs your heavy paper.)
As it comes out, it should have your stuck paper with it.
Jeremy
SOURCE: HP deskjet 1280 paper jam
Yes you can manually remove the paper. It can be pulled out from the feed area (pulled out backwards).
To clear the jam status....
Take the back cover off, there is a reset switch in the top left hand lock hole. Push a pen (or similar) into this hole, the switch will give slightly and be the same depth as the others.
put the cover back on, all should be well
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Testimonial: "Thanks so much for your help - problem solved."
