Question about LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive
Problem with Ethernet big disk (1to)
I cant acces to admin and the shares (data)...
Note on screen; /www/cgi-bin/public/sharelist: line 41: cannot create temp file for here document: No space left on device
Any idea without bring back the device to the store?!! Explain please each step if you can help.
Many thank!
  • tcheloS Jan 14, 2009
    Same problem here. Could not find any workaround yet.
Http://www.lacie.com/support/support_manifest.htm?id=10224&guideid=10627
If the web administration can not be accessed.
The button on the front of the drive can be pressed in a specific sequence.
Switch OFF the Ethernet Disk by holding the button until it begins flashing in a pattern. Release the button, and it will shut off shortly afterward.
Press and hold the power button. After a few seconds the light should begin to blink. Release the button.
Quickly after releasing the button (within ~3 seconds), the LED will blink, but at a different rhythm. Press and hold the button again.
The light will switch to a third rhythm. Release the button. It is now using the factory-installed firmware.
Regardless of the method used, all users and shares on the system are lost. The data is still on the drive, however. To restore the data, recreate the users and shares with their original names (through the Users, and Shares tabs, respectively.)
Posted on Apr 30, 2009
  • kennymacp Apr 30, 2009
    try using this...works for me though I have a host of other problems withthe thing. their tech support is quite proactive though.
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0; Trident/4.0; GTB6.6; SLCC1; .NET CLR 2.0.50727; Media Center PC 5.0; InfoPath.2; .NET CLR 3.5.30729; .NET CLR...
Dear Friend!
1st - remove the Internet Explorer 8.0 completely from your system.
2nd - download a fresh copy of Internet Explorer and install.
If you will facing same problem after installation, please use only Mozila firefox.
Best regards,
Pramod Bhikam Singh
Apr 26, 2011 | Microsoft Internet Explorer 8
None of the shares are being recognized on my LaCie Ethernet Raid Disk. When I log in to the web console my only option is to initialize the disks. Is there any way to recover the data on the drives?
Yes, the partitions are missing that's why it wants to initialize.
Download and run Test Disk from CGI Securities.
It's FREE and pretty straightforward.
Let me know if you have any problems or concerns.
Nov 23, 2009 | Video Game Consoles & Games
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file...
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jul 29, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Ethernet contoller
Try goining into the Bios setup screen and see if the ethernet is turned on.  Model number A105 - ???
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download#
Jan 04, 2009 | Toshiba Satellite A105 Notebook
Administrator password
default user administrator default password admin
Nov 07, 2006 | LaCie Ethernet Disk (300788) 1000 GB...
Open Questions:
See all LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive Questions
LaCie Ethernet Disk Mini, 500 GB Hard Disk Drive with Gigabit Ethernet & USB 2.0 Interface, 7200 rpm... IDE Hard Drive Logo
1,918 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
