On right side as you look from front is door secured with at least one screw; with set unplugged remove door and two more screws behind it that secure the lamp cartridge (it has a handle) and carefully pull it out----replacement lamp comes in one of two ways= just the bulb or the bulb with the cartridge.
Get the one with the whole cartridge, much easier to replace and "generic" ones are no bargain as they usually have a shorter life.
Carefully insert the new cartridge in being sure the two pin plug on the back engages correctly; NEVER TOUCH THE FACE OF THE LAMP WITH YOUR HAND as oil on your fingers can damage the lamp when it operates.
If you search the internet with the model number you will find a lot of sources for a replacement lamp.
Let me know here if you have questions.
SD TECH
