Question about Whirlpool Refrigerators
Have to change the frig water valve on Model GD25DFXFN01 GOLD, S/N SJ1552586. Ordered a part and believe we got the wrong one. What part do we need??? Thanks
We called a repair man and he fixed it in ten minutes. Saved a lot of hassle didn't have the misery of laying on the floor in a confined space, using a different part. First repair on this frig for nine years, so feel lucky. Thank you.
Posted on Aug 08, 2008
I Ordered a navy blue with gold Apple Watch when my son opened it today it was rose gold obviously aman isn't going to wear a rose gold watch. I ordered on dec 7
Personally I prefer the colour of rose gold...
Retailer might have sent you the rose gold model due to supply problems rather than send nothing. It might even have been done from good motives.
Double check your order to ensure you didn't click the wrong colour box by mistake and then contact the retailer if they really sent the wrong colour and advise them you are returning it for exchange or refund and expect them to refund your postage. You will need to use a premium service that is recorded and tracked and has adequate insurance cover.
Dec 26, 2016 | Watches
The ice maker in my Whirlpool Gold (Model GI6FDRXXY07) stopped making ice. I can get water from the door and can hear the ice maker cycling. It is calling for water but the flow valve is not opening.
The same valve that the water comes from except there are two halves to the valve. The valve you need is a=> Whirlpool Refrigerator Water Inlet Valve WPW10312696 The problem is with these models the ice maker tends to function a little causing you to believe it is OK when they are worn out. I can point you to a manual to see if the water valve works by going to page 18 HERE and use a jumper wire between test point L and the letter V. Make sure the wire is insulated so you don't get shocked. Otherwise the ice maker may need to be changed and it is less expensive than the water control valve Ice Maker=> HERE
APPLIANCE911
E-Mail Contact Me Here
Aug 29, 2016 | Whirlpool Refrigerators
I saw your response to another Kenmore frig and I have a similar problem I want to ask you about. I have a Side-by-side Kenmore frig(model 106.9555722) that we've had for 16 years!! Other than r
I have seen this one other time in all my years of appliance repair and changing out the "water inlet valve" corrected the problem. I don't have an answer to why it did, but it did. Here is the valve for your unit.
After you change the valve be sure to purge the water line for a good 5 - 10 mins to get all the nasty water out. Keep me posted!
Nov 24, 2012 | Kenmore Side by Side Refrigerator
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
The water dispenser and the ice maker have stopped working on my Whirlpool Gold GS5SHA. I have cleaned and defrosted the ice maker. The lines look clear. Any suggestions? Thank you.
Hello Kent, with the work you were doing on your frig did you shut off the water valve and just forget to turn it back on. This is a very common problem. Check and see, GOOD LUCK.
Oct 11, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker not running can't hear water running like normal - water does come out of the front door though.
your frig uses a dual valve one side for the foutain and other for ice maker . the valve may be at fault . . very common problem . replace it . mm
Sep 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold side by side ice maker not making ice... have replaced the ice maker... still not working, no water to unit... not frozen up... water dispenser is working fine
You have a dual solenoid water valve. Blue for the water and red for the ice-maker. It located in the rear lower part of the frig. The water solenoid needs replacing that will solve your problem. BB
Jan 21, 2010 | Refrigerators
Icemaker installation
excessive water pressure to the house?
deffective tubing ?
is he using the plastic ferrel and brass insert
if not you must
May 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ge gss22jerfcc side by side frig/freezer wiring diagram
the problem is your icemaker. there is one sure way to see if your old valve was good, hook up a water line to it and apply 110 volts to each valve and usually the valves have different size terminals on them. actually if you are getting water out of your dispenser than your friend did in fact hook up the valve correctly.
Apr 03, 2008 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
