Question about Apple iPhone Smartphone
I phone phone on ly shows on screen the itunes connection logo
I try to unlock iphone by iLiberty+ but is hung
Posted on Aug 09, 2008
My iphone screen wont work but the buttons will
Try restarting your device by holding down the Power button. If your screen still fails to respond, back up your data to iTunes on a computer. While still connected to the computer, turn off your device by holding the Power button, and the Home button. Don't release either button yet. When the Apple logo appears, let go of the Power button, but not the Home button. Then your iPhone should show a picture of connecting to iTunes. Then you can set up your device through your computer on iTunes, and your phone should work fine.
Dec 22, 2013 | Apple iPhone Smartphone
Iphone will not turn on! Shows Apple logo then fades out?
Leave the phone plugged into the car charger with the "plug into itunes" screen long enough to build a charge. It sounds like the phone is dying before it gets a chance to connect to itunes and start charging through the computer. If this does not work then the store clerk was correct and your battery will need replacing
Feb 09, 2013 | Apple iPhone Smartphone
Only in my iphone 3 apple logo cmng and itunes sign is coming with conector sign
That means you have to sync your phone with iTunes.
And to do that you must have an iTunes account (free) and the latest version of iTunes (free)
Then once you get those and iTunes installed, This is what you do
  1. Download and install the latest version of iTunes on your computer.
  2. Open iTunes.
  3. Connect the iOS device to your computer using the included USB cable and select it in iTunes under Devices on the left-hand side.
  4. Set up which items are to be synced: Click the corresponding tabs in iTunes to specify which information you want synced between the iOS device and your computer.
  5. Click Apply, in the lower-right corner of the screen, to sync.
I hope that helps you out. Anytime the Apple logo shows up with the iTunes logo that means the phone needs to by synced with iTunes and your apple account..
Thank you
Aug 21, 2011 | Apple iPhone 3G
I restored an iphone 3g via itunes and then tried to start it. it is stuck in emergency mode and shows the itunes connect logo's and at the top of the screen there is a lock logo in a locked position....
Sir,
Your phone is locked kindly go to the mechanic and opened the lock , if your cell phone is unlocked then only you can use other wise your phone is gone bad
May 20, 2011 | Cell Phones
Phone doesn't start nor does iTunes restore, it just stuck on the apple logo start-up screen. On i tunes the error code 3194 shows up. what can i do ?
1. Open iTunes and connect the iPhone to your System (PC/Laptop).
2. Press and hold the Home button and the Sleep/Wake button at the same time
3. After exactly 10 seconds release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
4. The iPhone screen will remain black
It may take a few attempts to get your iPhone into DFU mode. Generally, I hold down both buttons then release the Home button just before I think the Apple logo would appear. If you are still holding both buttons down and you see the Apple logo you are holding them down for too long
then try to perform the restore on itunes, if that did not work post a comment so I can assist you.
Mar 26, 2011 | Apple iPhone 3G
My jailbroken iphone2G screen shows only logo of itunes & usb cabel photo after i downloaded itunes 10 & created fake a/c on itunes. it can recognise but can't restore & update. I have cydia...
hi i am too from india just 14 years old press the sleep button and home button simultaneously for abou 10 to 15 sec the your device will show you the apple logo wait for 5 to 10 mins and now you can restore make sure you first connect your device and then reboot or maybe itunes is taking that much time because your firmware is old to be updated
Feb 15, 2011 | Apple iPhone Smartphone
I hooked my iphone3G to the computer and it stay on the first apple screen and hasnt went any further...what can i do to fix it?
HI
Unplug the phone from the computer and power down then try holding the power button and the home button for around ten seconds the screen should show the apple logo and release the buttons then wait and see if the phone loads up to the home screen.....this can take while for the phone to register so dont push at the buttons etc just see if it changes. If not then follow the steps below to put your phone into recovery mode and restore it
Hope this helps
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option. If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    After a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Jan 01, 2011 | Apple iPhone 3G
My iphone 3GS is stuck at the Apple screen. I've tried holding the off and home buttons to reset, but it's not working
This is not a good sign and one of the most common causes with this device. I could tell you a series of troubleshoot.If that would not work, device needs to be send for repair.
Have you tried a hard reset? Hold the Home and Sleep buttons together for 10-15 seconds, until you see the Apple logo come up on the screen. You may need to do this while the phone is plugged into it's charger or a computer, so that it has power.
Usually If it's stuck at that screen, and holding the buttons together for 10-15 seconds didn't help, then there's a hardware issue, and it will need to be replaced.
However, try few more steps
1. Connect to iTunes via USB. Do not disconnect for rest of these steps. iTunes may appear frozen or stuck with spinning beachball....this is okay, do not Force Quit iTunes. I tried a few times w/o it being connected to iTunes and it doesn't work.
2. Once connected, hold Home + Power until screen blinks then Apple logo comes back up.
3. Wait until Apple logo dims slightly (~5 minutes or less). Do NOT reboot until the apple logo dims.
4. Hold Home + Power again until it reboots and Apple logo comes back up.
5. After 2 min or so, the phone may vibrate once or twice. Continue waiting for the full 5 min until Apple logo dims slightly. iTunes at this stage MAY recognize the phone...do not sync or do anything in iTunes.
6. Hold Home + Power for the 3rd time until it reboots. Phone may vibrate again after 2 minutes or so. Eventually you'll break into your Home screen.
Or
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Disconnect you phone from your pc leaving the wire connected to your phone not your pc.
open itunes
hold sleep wake button + home button until your screen goes blank...
let go of sleep wake button and continue to hold home while plugging back into pc... should take about 15-30sec and itunes will see your phone in restore mode
IF THIS NOT WORKING
Try rebooting you phone by plugging it into the charger & turn wall socket on
If that also does not work then you need to take it the apple store.. They will replace it or service it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 28, 2010 | Apple iPhone 3G
My iphone 3gs willnot on and not show me the apple logo
Instead of trying to update when you connect to iTunes you should try to restore the phone completely.
You can find the restore button in the lower right hand corner of your screen. If iTunes asks if you want to update click cancel. You just want to restore.
If it is still not turning on after it reappears in iTunes you should take it to Apple if it is still under warranty they will exchange it for you.
Feb 05, 2010 | Apple iPhone 3G
ITouch screen locked and showing iTunes logo
try to plug the itouch into a charger/computer.
its probably dead.
Feb 25, 2009 | Apple iPod touch
Apple iPhone Smartphone Logo
82 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
