Question about DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I recently bought this DVR-625 new on EBAY. Dish came out to install on 7/28/08 and found that the local channels have distorted (crackling) audio. It’s the audio for the local channels and some of the Sirius radio channels only, the audio on the entire remaining channels work fine. The second TV has no problem; it’s only to the TV connected to the receiver. I called Dish tech support and they checked that the latest software was installed and turned it over to their engineers. They could not figure it out and set up a service call. A service tech came out, did all his testing, and confirmed that it is a problem with the receiver. They would not trade it out or send for repair since it is not their receiver. HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Scholar:
    New Friend:
  • DISH Network Expert
  • 74 Answers
Bypass any connections, such as running the composite cables or coax through VCR. Hook up from the box straight to the tv.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brian_142c5ec89a7a3fda
Posted on Sep 08, 2013
  • 374 Answers
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Posted on Aug 27, 2008
SOURCE:
Why does my Dish Network DVR-625 DTV receiver sound like it is running all the time
The Dish 625 as with the other Dish DVR systems has a fan built into the back of the unit. The fan runs nearly all the time to keep the internal drive cool. Sometimes the fan sounds louder that normal. what I do from time to time is take my shop vac and or the small vac u you use to clean your computer. and clean the vents around the fan. I do this on my desk top computer also.. Hope this helps.
Sep 03, 2014 | DISH Network DVR-625 DTV Receiver /...
I have dish Network DVR-625 DTV Receiver, I want to hook up a Xfinity cable modem. How do I achieve this
The 625 receiver does not support any internet functionality. You would need to upgrade to a newer receiver box.
Sep 26, 2013 | DISH Network DVR-625 DTV Receiver /...
How do I get closed captioning on my 625 dish dvr.
Guest,
The 625 receiver does not have a setting to control closed caption. This is a setting from your TV itself. I would look at your TV manual to see how you can turn the feature on. I hope this helps.
Ray Calo
DISH Network
May 19, 2010 | DISH Network DVR-625 DTV Receiver /...
How do i use the ant. passthrough on tv2 in dual mode w/ dish dvr625
ANT. passthrough for an ant. connected to your 625 receiver will only work on tv 1. The only way to do this is to RF modulate your tv 2 coax to an RCA and hook the RcA cable to your tv2. then use another ant. to connect coax allowing you to pick up dish programing on an input and then going to the channels to enjoy local over the air programming.
Nov 26, 2009 | DISH Network DVR-625 DTV Receiver /...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Can I record antenaTV on my Dish PVR-625
Officially, no you would not be able to since you no longer pay the $5.98 DVR fee which Dish charges for the DVR. Wish I could have given you better news. Thanks for using Fix Ya and let me know if I can further assist you.
Dec 26, 2008 | DISH Network DVR-625 DTV Receiver /...
Installing a DVR
You are not able to use the DVR unless you have Dish Network services. Cable operates at a different frequency than Dish Networks Dish Pro Plus Receivers.
Sep 07, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 - Audio Problem
FIRST TRY CONNECTING THE RECEIVER TO THE TV VIA A DIFFERENT MEDIUM SUCH AS RCA INPUTS IF CURRENTLY CONNECTED WITH COAX.
If the problem is still evident you can send the TV1signal to TV2 or vice versa. This is accomplished by switching the output cables from tv 1 to tv 2 and changing the tv you want to use as your "monitor" to the proper channel. If viewing tv1 on tv2 change the TV channel from 60 air or 73 cable to 3. if using tv1 to view tv2 the process is the oppposite from 3 to 60air or 73cable.
To check which channel tv2 is modulated to do the following:
go to TV2 and with it on press menu, 6, 1, and then 5 on the Dish remote. That will dispay both tv output channels. You only need to be concerned with TV2.
This should isolate the problem by either it being present on both TV's using the TV1 output, which would mean the internals of the receiver are faulty, or if it is fine on the other TV it would indicate that the problem lies with the TV itself which is unlikely.This is assuming the FIRST method did noyt resolve the problem.
You may also want to try running the medium source from the back of the receiver directly to the TV.
This is all assuming you receive your locals through the satellite and not an off air antenna. Hope this helps you out.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
Dish Network 625 Receiver Problem
sounds like a bad hard drive, is there a number in the top left corner of the attention box??
Jan 23, 2008 | DISH Network DVR-625 DTV Receiver /...
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder Logo
225 people viewed this question
Top DISH Network Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
matt martin
matt martin
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
