Question about Siemens Lands Phones
Siemens sl30 phone wont charge. Just blinks the last part of the battery. When I turn on the speakerphone to dial the phone dies and shuts off. when regular dialing can hear crackling static
I have similar problem with my gigaset 4000 micro, i bought 600mah NiMh bettery and when I start charging it charges cca 3 min and displays that battery is full and it doesnt charge it any more. I can speak max 12 minutes and phone starts beeping that battery is empty. What should i do to make phone to charge this battery properly.
Posted on Jan 27, 2011
How do I fix my siemens landline phone?
well lightening does do bad things to telephones . that are always plugged in to electric and phone lines
Feb 25, 2015 | Siemens Gigaset A58H DECT 6.0 Digital...
Samsung Savyy wont trun on. it blinks red
please use other samsung battery same as your phone if not the issue is on the phone it self.
Dec 20, 2013 | Cell Phones
V tech dect 6.0...both my handsets die out when i go to use the speakerphone..Is it time to replace the batteries as I've had these phones for over two years now?
Try to fully charge them first and check for how long do they keep charge. But, yes, for some batteries 250-300 recharge cycles is a life span.
Nov 23, 2011 | Vtech Cordless 6041 Phone
Phone turn off when speaker is turn on and it disconnect when it turns off
If it is the handset speakerphone, this usually means the battery is dying. The speakerphone uses more power than the regular phone, so when you turn on the speakerphone with a weak battery the handset will shut off and disconnect the call. You likely need a new battery.
Mar 23, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
No sound unless in speakerphone mode. It rings & dials just fine. However, when I flip it open, I can't hear the caller. I can communicate normally if I switch into speakerphone mode. This is a recent...
Seriously, sometimes if you have the other person yell, it will just magically "pop" back in. THis only lasts a few minutes though. Unless you can deal with speaker phone, I suggest a new phone.
Jul 02, 2009 | LG CU400 Cellular Phone
Wont turn on
pull the battery and try to power on. if no good test the power adapter with a meter - should give 18-19 volts. if it boots with battery off, power up and put battery back on to charge.
hope this helps
Jan 17, 2009 | Acer TravelMate 6460 (LX.TED0Z.071) PC...
Adding new expansion handset
You will need to register it to your base station before it will work. You do so by holding down the registration/page key on the bottom of your base for a couple of seconds, and then grab your SL30 and push Menu, scroll down to the option of Handset settings, press OK, then scroll to "registration" and push OK, select base station 1, press OK, then enter the default pin of 0000 and press ok. Repeat these steps if first not successful. You can download a manual for free on our website at www.cordlessrepair.com
May 21, 2007 | Siemens Gigaset SL30 Cordless Expansion...
Lands Phones Logo
734 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
