Question about Brother DCP 115C All-In-One InkJet Printer
Error 46 unable to clean can you help me about problem my printer brother dcp 130 c thank you.....
    Problem Solver:
Did you already fix it? my printer is also dcp 130 c... it says unable to clean 46
thannks
Posted on Aug 23, 2008
    Problem Solver:
  • 7 Answers
Reset your printer and press the up and down aroow keys together four times.
Posted on Jul 16, 2009
3 Suggested Answers
  • 525 Answers
SOURCE: clean unable 46 error on dcp 135c brother printer
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Jan 23, 2011
SOURCE: DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
Posted on Jun 06, 2010
Unable to clean error 46 Printer Brother DCP-6690cw
my DCP 6690 printer causes problem unable to clean 46 how can i solved this ..............
Jun 12, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Error 46 and says unable to clean. can u help me plz
According to the manual, the unable to clean error means a mechanical problem or a foreign object in the machine: Open the scanner cover and remove
any foreign obstacles inside the
machine. If the error message
continues, disconnect the machine
from the power source for several
minutes then reconnect it.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002010/BH3eDCPWLAN_UkEngUsr.pdf
Apr 24, 2009 | Brother DCP-340CW All-In-One InkJet...
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean 46
posted fix in another prob same section
Aug 23, 2008 | Brother DCP 130C All-In-One InkJet Printer
DCP-330C All in one
Hi. I had unable to print and unable to init 46 error. Any help available to reset my machine please. Thank you
Jul 27, 2008 | Brother DCP-110C All-In-One InkJet Printer
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 115C All-In-One InkJet Printer Logo
566 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
