Question about RCA D52W19 52" Rear Projection Television
Power button blinks 3 times
I also have this problem ,about 2 months ago my tv didnt turn on.finally it came on and i never turned it off again,then yesterday the power went off for about 3 hours and now the light blinks 3 times,you can hear it click at the same time. when i hold the power button down it starts flashing,1 then 9 figure its self diagnostics.,maybe a code 19? trying to figure it out so i can fix it
  • jamtam Aug 08, 2008
    if i change the flyback do i have to change the horizontal output also?
  • RCA Master
  • 8,617 Answers
You need to replace the flyback, and that will fix your set. You can get a replacment flyback at the following link and they will provide free online instant messaging when you do the repair so they can take you through the replacement step by step. You need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Posted on Aug 08, 2008
  • Sonny Berry
    Sonny Berry Aug 08, 2008
    Usually if the led blinks three times the horizontal output is still good, But it may be wise to replace it anyway as the HOT and the flyback work in conjunction with each other.
Samsung startup problem
serial number on 6.17.8.1
Sep 21, 2013 | Televison & Video
Power surge from storm. Power light turns on for 2-3 seconds and goes off. Previously had a power supply replaced 3 yrs ago. tv is approx 12-15 yrs old.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
before you rate this information or if you have questions let me know what you find.
SD TECH
Jul 25, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Tv turns on then off after a few seconds. No picture or sound in these few seconds.
Try this and let me know what you find:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
if this has helped you rate this solution as I do this here for free.
SD TECH
Dec 10, 2009 | Mitsubishi WS-55511 55" Rear Projection...
9 months ago our Mitsub WS-65611 starting turning
The part number you indicate is the STK-393-110 convergence IC that this set uses--it is possible it is bad again--if properly installed it should not have failed for at least 5 years.
When the set shuts off, on the front of the set engage the self check feature this set has: when the power light goes off ON THE FRONT OF THE TV press both the MENU and INPUT buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example--2 blinks, a pause and 2 blinks--this is the most common and it will repeat the code several times.
Let me know what you find---I am here to help people.
If this information helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 16, 2009 | Televison & Video
Power light flashed red 4 times then repeats no pic,new bulb/fan!
Check the fan that cools the bulb. It is directly behing the bulb. It should turn on when the power comes on. It apparently has a safety to protect your tv(and home). mine is in the process of going out. looking for online solutions as we speak.
Jul 19, 2009 | Sony KDS-R50XBR1 50" HDTV
It takes 5 to 7 minutes to turn on my Magnavox HD TV
IFyou feel confident and can locate switch mode power supply with back removed.
Try warming switchmode power supply before turning TV on.
If TV turns on normaly then there are some small capcitors that are a common cause of this fault.
Otherwise look for DRY or CRACKED solder jointson PCB
BUT DON'T do any of the above if your are not confident send it to a TV repaiman.
Sep 11, 2008 | Philips Magnavox MS2530C 25" TV
WORKS 3 MIN AND SHUTS OFF
If it is the power LED that is flashing orange 2times every five seconds , it suggests that the Lamp Cover was not reinstalled correctly. Remove and reinstall it
Jul 13, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Mitsubishi wt-42413 Power problem
Okay try to distinguish if the three blinks is 1 pause then 2 blinks or 2blinks pause 1 blink. As the set will only blink a two digit code 12 meaning no error detected and 21 meaning the set is hutdown due to xray protection.
May 13, 2008 | Mitsubishi WT-42413 42" Rear Projection...
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
