Question about SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG)
But... Yes, I have seen that tutorial. My question is: as I am using uTorrent in my laptop (connecting via wireless to the internet) do I have to make a different configuration on the router? Because I followed those steps on te tutorial and it always reply saying the port is closed... :S Sorry, noob.... :P
    Sergeant:
    Champion:
  • 236 Answers
You're supposed to change the port on uTorrent to another that is different from the one you setup with the desktop fowarded.
and the ip address for the laptop is (has to be) different than the one you get if you were on the desktop.
Posted on Aug 08, 2008
SOURCE:
I have a HP Officejet Pro 8500 printer, Model No. A909a. Is it a wireless printer? Can I connect my laptop to the printer with an ethernet cable?
Yes to both your questions!
If your laptop has wireless you need not use the cable if you connect via wireless to the internet router, you can use printer wireless to , you just need to seup the laptop to use the facilty.
You setup the printer through "Tools" look for Network and "Wireles Setup Wizard"
Same applies with the laptop through control panel.
Mar 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Due to a crash, I have to re-install windows on my hp nx5000 laptop. I would use XP or Vista, it doesn't matter. I've tried to use XP again, but lost the wireless drivers to connect to the internet. Either...
IF you somehow managed to install the LAN ETHERNET connection then there is a big chancethat there is good solution to your problem.
Using your Laptop *d one dat is formatted recently*Plug in your Ethernet RJ45 cable and log on to the Internet(assuming that your Wired LAN is installed)
Download the Utorrent at www.utorrent.com and INSTALLthen go to download THIS
If you just want to download it LEGALLY then GO HERE
PART 2
INSTALL the software if its a pirated version then crack and put in the the serialRESTART program and Scan All HardwareDOWNLOAD drivers as specifiedINSTALL the drivers PROBLEMS SOLVED
Feb 19, 2011 | HP Compaq nx5000 Notebook
Wireless cards is it built in
If you are referring to the notebook having wireless connectivity (being able to connect to the internet via your wireless modem) then YES!
It comes with the Intel High Definition audio modem and 10/100 Base T PCI LAN on board, which will allow you to connect to the internet. You can also use the RJ45 plug to connect to your modem with an ethernet cable.
Nov 19, 2009 | ASUS A3H Notebook
Cannot connect lap top or printer wireless and also connect to the internet via AT&T motorola modem
yes. Here is Linksys' page on how to:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 12, 2009 | Linksys Wireless-G WRT54G Router
Again... :o)
Your computer should be on a static IP and dns in order for you to specify to which computer will be the port for the Utorrent will be working, because in order for the port forwarding to work fine you need to set the excat Ip address that the port will be using...
Aug 08, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
SMC Barricade g SMCWBRT14T-G router
You need to open the port that Utorrent is using check this link for the step by step way on how to do that on the utorrent and on the router http://portforward.com/english/routers/port_forwarding/SMC/WBR14T-G/Utorrent.htm
Hope that helps..............
Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
May 21, 2008 | Dell Inspiron E1505 Notebook
Iam trying to connect my laptop to the innet. i have wrt54g router.
Hi jjroyc
Let's see if we can get your laptop connected to the Internet.
First, I have some questions and a few instructions for you.
(01) Is this a new (to you) router?
(02) Do you already have one or more computers connecting successfully to the Internet using this router?
(03) If yes, are any of them connecting wirelessly?
(04) Have you recently (at another location for example) successfully connected this laptop to the Internet? If so, did you connect it "wired" or "wirelessly".
(05) Are you trying to connect your laptop to your router "wirelessly" or "wired"?
(06) If you are trying to connect the laptop wirelessly, turn off your laptop's wireless radio and connect the laptop to the router "wired" instead (using an "Ethernet Patch Cable"). Once we've established that the laptop is capable of connecting to the Internet via the simpler "wired" connection, then we'll move on to the more complex wireless connection.
(07) Please, go HERE to download the manual for your particular router. You will need to determine the version number of the WRT54G model 1st. There are instructions there that will guide you through this.
BJ
Apr 03, 2008 | Computers & Internet
Open Questions:
MALWAREBYTES cUsToMeR SuPpOrT PhOnE I:855:,:5365666 NuMbEr .U.S.A AsIf This MALWAREBYTES aNtIvIrUs USA phone number is ranked #2 out of 2 because 7,728 MALWAREBYTES aNtIvIrUs USA customers tried our t55ls and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the MALWAREBYTES aNtIvIrUs USA customer Support department for problems like Where to buy, Complaint, customer support, Repairs, Returns. As far as we can tell, MALWAREBYTES aNtIvIrUs USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. MALWAREBYTES aNtIvIrUs USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact MALWAREBYTES aNtIvIrUs USA with help from customers like yourself. Please help us continue to grow and improve this information and these t55ls by sharing with people you know who might find it useful. Calling MALWAREBYTES aNtIvIrUs USA Calling MALWAREBYTES aNtIvIrUs USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back t55l. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from MALWAREBYTES aNtIvIrUs USA customer Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with MALWAREBYTES aNtIvIrUs USA's customer Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare MALWAREBYTES aNtIvIrUs USA's phone numbers against each other. Contacting MALWAREBYTES aNtIvIrUs USA in General While I********** is MALWAREBYTES aNtIvIrUs USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to l55k at as well. One thing to keep in mind as you try to reach MALWAREBYTES aNtIvIrUs USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact MALWAREBYTES aNtIvIrUs USA.
Oct 19, 2019 | Best Computers & Internet
Aol phone number for password reset~18OO8O31-O69 dcgl Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Technical support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Technical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Technical support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their technical support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their technical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
Oct 19, 2019 | AOL Computers & Internet
AoL technical sUpPort pHone~18OO8O31-O69 nUmbeR cgl Usa AOL USA phone number is ranked #2 out of 2 because 7,728 AOL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO::8O31069 is to reach t he AOL USA Technical support department for problems like Where to buy, Complaint, Technical support, Repairs, Returns. As far as we can tell, AOL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AOL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact AOL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AOL USA Calling AOL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AOL USA Technical support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AOL USA's Technical support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AOL USA's phone numbers against each other. Contacting AOL USA in General While I8OO8O31O69 is AOL USA's #2 most popular phone number, it's not the only way to get a hold of their technical support team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AOL USA help by calling them, is that other customers give their technical support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AOL USA.
See all SMC Barricade g SMCWBR14T-G Wireless Router Questions
SMC Barricade g SMCWBR14T-G Wireless Router (SMCWBR14TG) Logo
103 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Kris
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
