Question about Teac LSR 200 System
Teac powered subwoofer
The fues keep blowing out is their a local surives i can have it look at i live in zip 14031
Many things can cause this. Bad decoupling capacitors, blown power output transistors, 2sa1941/2sc5198 and associated drivers, bad voltage doubler capacitors, or simply a bad primary power rectifier. It can be fixed but the question becomes... is it worth it??? I have thre of these and all of them have failed at one time or another. I fix my own or I would have just trashed them.... jerrytrammell@verizon.net
Posted on Sep 13, 2008
I am unable to find the owners manual for the Teac MC-DV100 SuybWoofer
For almost any set-top box, there isn't a sub-woofer output. Without that output (it would be labeled on the STB), you can't hook up a subwoofer directly to it.
HOWEVER, the model number you give isn't just a subwoofer: it's a whole sound system with a subwoofer attached to it. If you have the whole sound system, you just hook the STB's audio output to the amplifier's "Aux Input" (it might also be called "line input").
If your model doesn't have that (can't tell from the web), you'd have to buy an "AV Receiver" that has at least a 5.1 set of outputs. These start at maybe $150 new, $50 on eBay. MAKE SURE YOU BUY A RECEIVER WITH A "powered" SUBWOOFER OUTPUT!! You connect the receiver to the STB, and the subwoofer to the receiver.
Jul 15, 2015 | Teac Audio Players & Recorders
Keeps blowing fuses
You need to be very specific about your question. When people see "Glow Plugs" one thinks about Diesel Engines and not Car Audio.
Jan 15, 2014 | Car Audio & Video
I'm fues to my fan keeps going out on my 2006 P.T
More than likely you have an internal fault either in the fan itself or the thermostat that activates it.
For a fuse to blow it has to have a lot higher than normal current draw through it, which is normally refered to as a short. If the fuse blows almost immediately then I would suggest you unplug the fan, and see if the fuse blows with just the thermostat in the circuit. If it blows - replace the thermostat control. If it doesn't blow, plug in the fan and watch it. If it trys to start and then blows the fuse, replace the fan motor.
Jun 30, 2011 | 2006 Chrysler PT Cruiser
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Every time i turn the ignition on,, a 20amp fues blow out ..the car is not starting..it will turn over but not start... the fues is in the power distibutor box only
what is that fuse for? If it keeps blowing then it is an indication of a short cicuit in the part/cable/wire for the unit the fuse protects.
Oct 03, 2009 | 1997 Ford Thunderbird LX
Fuse blows everytime i turn it on
the blue coloured varacter in your power supply circuit needs to be changed
Mar 30, 2009 | Teac AG-V3050 Receiver
Why do my fues keep blowing on my daewoo
First I suggest confirm what fuse blowing there and waht circuit and edevices are controled, check some wire broken or bad ground in the line and switch (if have one there).
Keep us updated.
Mar 27, 2009 | 2001 Daewoo Leganza
I have a teac AG D8900 Digital Home Theater. My subwoofer seems to be dead. No lights come on the front of Sub Woofer even though it's plugged in. I tried changing outlets. The wire from speaker to...
I have the same-just talked to TEAC last week, if fuses(two 5 amp glass ones inside housing-just remove screws on back after un-plugging 120v power) on the LSR-1008 subwoofer are blown, it may be failed relays. I replaced my fuses, both blew w/in 5 seconds. Called TEAC today, relays are NOT available alone and are solder connected; however, complete new circuit board is plug in, part #APE000515-0001 at $47.69 plus shipping. Verify #s and price with TEAC, but now I must decide if it's important to keep this sub, or if another at around 60$ on Ebay is a better bet. Good luck!
Dec 26, 2008 | Teac AG-D8900 Receiver
Blowing fues
Are you sure you can put a 2 ohm load on this amp? Thats almost a complete short.
Jun 13, 2007 | Rockford Fosgate Punch 301S Car Audio...
Teac LSR 200 System Logo
272 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
