Question about Carrier Heating & Cooling
Ihave a Bryant by Carrier model 376CAV108095 furnace purchased in 1991. The last two years the unit rattles all the time or with just the fan on like there is a loose component inside. It is a downflow. I checked the heat tubes I could reach from the AC coil and nothing is loose. The rattle is not coming from te circ blower either , it is somewherer in the middle. How do I fix the problem?
  • 1,512 Answers
G'day
It sounds like a worn bearing for the fan, rattling because of the clearances and the slightly out of balance fan blades. Replacing the motor, or having it re bushed will fix the problem. A unit of this age, has pretty much reached the end of its life anyways. May be time for a replacement.
regards
robotek
Posted on Sep 14, 2008
  • 13,433 Answers
Hey,
If the noise is not coming from the fan, then something is most likely loose. I think you will have to take the AC apart and find what is making the noise, possibly loose screws - bolts. Something possibly gotten loose over the years.
I have a Carrier model # 58MXA080-F-15112. I think my furnace is 30 plus years old. it isn't heating properly. The blower turns on and sometimes the flames come on, but sometimes they don't. As...
A 13 code means the furnace cycled on limit more than three times consecutively and is in a lockout for 3 hours. A 14 is ignition lockout. An ignitor does not intermittently quit working. I'm the service mgr at our shop, and I know that particular furnace model has a service bulletin out on bad secondary heat exchangers. If your lucky the filter is dirty, or the furnace condensate trap or drain is clogged. Most likely the secondary heat exchanger is plugged up and isn't allowing the pressure switch to make. Or the furnace is overheating due to it not being able to properly vent hot gas. Which would explain the high limit lockouts. Call an authorized carrier dealer so you can take advantage of the free heat exchangers and the $300 labor credit. You can also call an authorized Bryant dealer to perform the work for you. Only an authorized dealer can rectify this problem because the Bryant corp requires testing and paperwork in order to get your free parts and labor credit.
Good luck.
Dec 23, 2012 | Heating & Cooling
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
I've been having the same problem with my Day & Night Bryant Carrier furnace that is described here http://www.fixya.com/support/t3213886-bryant_carrier_furnace_fan_stays. A repair person says I should...
if you are going high effiency you would have to replace outside unit as well. very expensive. if unit is less then 10 years old repair if not replace.
Dec 01, 2010 | Bryant 462AJC021BA Air Conditioner
Bryant-Carrier Furnace Fan Stays On
I suspect a bad fan relay or bad fan control. Maybe the longer the control or relay is in the on position the more chance of it sticking on.
Oct 17, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant furnance clicking, won't fire
try checking the pressure sensing switch,it has a tube that should run somewhere close to the inducer fan.sometimes this hose fills with liquids,and makes the units act funny.I don't know if you have a condensing unit or what.the furnace wont try to light if it cant tell the inducer motor is running.any induced draft unit will work this way.you can also do a temp. bypass of the pressure switch to make sure the contacts on it are closing just be sure your inducer fan is running,and you cant leave it like that its just a test.that is a safety feature you really need.
Mar 11, 2009 | Heating & Cooling
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
