Question about E-Machines eView 17f 17" CRT Monitor
No Power It worked perfect then I unpluged it and moved it then I tried turning it on but no power then about 15 minutes later it turned on by itself, then I pushed the power button to turn it off and when I tried to turn it on it did it again, now when I tried to turn it on it doesn't turn on at all. It also doesn't seem to be damaged inside or out
  • E-Machines Master
  • 5,568 Answers
This is pretty characteristic of a failed power supply.
To verify that, one needs a capacitance meter that can measure not only the value of the capacitance but also their losses.
The problem stems from a weakness in the high frequency switching power supplies used in nearly all modern electronics. There are points in the feedback path where a type of chemical cap is used (electrolytic) that does not fare well handling high frequencies and eventually dries out internally or splits its case, losing its capacitance and developing losses that upset the feedback and finally do not pass enough signal to start and maintain the oscillations necessary to operate.
A tech with the mentioned meter could likely find this pretty quick but you need to ask if you want to invest the cost of a repair. The parts cost is minimal, probably under $2 US, but labor is costly and increasingly hard to find.
I have exactly the same monitor and when it comes time, I will repair it (when it still made sense, I repaired monitors - probably over 2,000 of them) since I have the required instruments and parts and also know how to prevent this from recurring - at least in my lifetime.
Posted on Aug 08, 2008
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Nec nlt-19hdb3 lcd tv turns on, boots ok, then powers itself off after about 15 secs
Power supply board have problems.Tries unplug,replug the tv an hour later,the tv now,will reset itself back to factory setting.The tv should work now,not than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 11, 2010 | NEC ONYX NLT-19HDB3 19 in. LCD TV
Power turns off by itself once in a while. i turn
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Feb 25, 2010 | Mitsubishi WS-65311 65" Rear Projection...
MP 610 won't turn on
unplug power cord for 15 minutes and it should reset.
Sep 22, 2009 | Canon MP610 Photo All-In-One Printer
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
Power turns off automatically
happened with my 2002 42" model. they say the convergence circuit.
Mar 10, 2007 | Mitsubishi VS-60707 60" Rear Projection...
E-Machines eView 17f 17" CRT Monitor Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
