Question about Canon PIXMA MP150 All-In-One InkJet Printer
Mstr2kx what is service manual error 6000 on ip1800
  • if_carmine_9 Aug 08, 2008
    I have um problem with the canon mp 150 l just 'turn me orange flashes the triangle and scriv and 4 0
  • vikas_prajap Oct 14, 2008
    Plz help me to resolve error 6000 canon
Why be such a lameass with this remark. Really helpfull you must have a world brand like HP (speaking about plastic fantastic) ahum anyways..
My mx318 does the same since i have a inktank. I open the printer, then put it on so that the printhead can move aroudn then close it..done works again.
Posted on Sep 23, 2008
THROW IT TO RECYCLE
Posted on Aug 30, 2008
SOURCE:
Service error 5100 and 6000
Canon tells you to unplug the machine without the head in for 30 minutes.
Replug into outlet and cross fingers./
If that does not work you may need a new printer
Feb 11, 2014 | Canon PIXMA iP1800 Printer
Service error 6000
The service manual is located here: http://servicemode.ru/images/stories/files/kyosera_fs_1010_sm.pdf
Under section 6-16 you can find error (5) 6000.
It is a fuser unit error.
Jan 12, 2014 | Kyocera FS-1016 Printer
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the...
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
What is error 6000 in a printer canon pixma 1800
6000 is a line feed error, either the platen roller is not turning or the sensor is dirty. Mostly I find something has fallen into the paper tray at the rear and jammed into the roller. From the front you can push an index card back thru under the guides and over the roller to push anything back. Usually a mark on the platen roller will show where something is jammed. The card can't go back thru the right side as it could break the sensor arm.
Dec 17, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I have a pixma ip1300 printer my problem is everytime i print it warns me service error 6000..what should i do?
The error 6000 is a paperjam error. It can be a very small piece of paper or debris. Open all covers and using a flashlight, look carefully for anything you can find and remove it.
You can also pick up your printer, turn it upside down and gently shake it so that anything in the printer will fall out. You may be surprised at what you see.
Oct 23, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Oct 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 Service error 5600
step 1: remove printer cable from your printer
step 2: you have to delete any files found in this folder C:\WINDOWS\system32\spool\PRINTERS
step 3: restart computer
May 14, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
What is service error 6000?
You have a paper jam somewhere. Cannon printers are very sensitive to any small pieces of paper trapped in the rollers.
Apr 29, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
What is service error 6000 for Canon PIXMA iP1800?
Error 6000 means - The specified file could not be encrypted.
Solution: reinstall the printer driver.... it's better to install a upgraded version of driver...
Feb 26, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
315 people viewed this question
Clive
Clive
old marine
old marine
Ekse
