Have you checked the BIOS jumper? Sometimes it needs to be seeded as per the manual the other thing to check would be to make sure your start button functions, I have had a bad button on a tower before. You should be able to use a small screw driver or paper clip and jumper over the posts for the start button on the Mother board and see if you get anything. This might have already been checked, but are you sure the Power supply is ok? You may already know this as well but just verify your ram is in the "0" slot as well.
Do you get any beep codes if you take out the memory and try starting? Do you get any lights on the MB? Do you see any fan movement at all when you try to turn it on?
No. Absolute silence. I just put in new memory modules just in case - the fan on both the power supply and the cpu fan do not move. I know the power supply works because if I take all the connectors off the motherboard it turns on. I also know that the power supply is working because I hooked up the connectors to the cd drives and they worked. I also did the old paper clip in the green and black wires of the 24 pin connector and the fans worked. I am not sure what else to try
