Question about Amana Refrigerators
Amana bc21vc has bottom freezer- freezer works fine fridge is warm already melted the ice build up in back of freezer twice in the last six months, had a repair guy form sears the first time he replaced some heater unit and melted the ice thats how I knew to do that. What do you suggest?
  • 958 Answers
look at the back wall of the freezer compartment, see if there is frost accumulation again. this would indicate a defrosting problem.
one your heater could again be busted, second is your bi-metalic disc that controls the heater from over heating is open , third is your defrost controller, either a digital electronic one or a mechanical timer.
anyone of these items are broken, you can only use your refrigerator for 1 week., but based from your story, if it would only happen twice in 6 months,
it could be gasket not properly fiited, air and moisture is coming to the ref and frost accumulation is faster and the heater can not cope with the frost.
check all gasket fitting at both doors to see if they really make a good seal. back to front and underneath the door.
i hope i was able to fix ur problem...
Posted on Aug 08, 2008
  • 158 Answers
The heater installed by Sears repair was probably an ANTI-CONDENSATION HEATER. The purpose of this part is to keep moisture from forming water drops (condensation) on the vertical surfaces of the refrigerator. There is usually an ENERGY SAVER switch somewhere inside the refrigerator so you can turn off the heater during dry weather. As for the refrigerator being too warm, try this: Purchase a REFRIGERATOR THERMOMETER from a hardware or appliance store. Place it inside the refrigerator, noting the temperature , then each day place it in a different spot inside the refrigerator, noting the temperature at each location. IDEALLY, THE TEMP SHOULD BE ABOUT 36 TO 38 DEGREES F,IN ANY LOCATION. Try using the temperature and usage controls in the ref to set the temp, and wait a day for the fridge to stabilize before reading the thermometer. IIf the temp cannot stay in adjustment, or is not uniform, call the repair man and show him your notes how the temp varies. This will allow him to pinpoint the problem more accurately.
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
My freezer is freezing food fine but my refrigerator seems to be warm and not cooling like it should. The temp control has been adjusted to a higher setting but does not seem to help.
if your freezer is working your fridge is fine
Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer working but fan not on in fridge - where to locate fan?
May be ice build up - happened with mine. Had to defrost completely (unplug for 24+ hours) then it worked fine on restarting.
Aug 15, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Kenmore Elite 596755 - Freezer warm, Ice Melted, then...
did you move it or tip it on its side when these devices are moved sometimes it will create anair pocket in the cooling system after moveing let stand for a few hours before plugging back in.
Jan 15, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My amana bottom freezer won't cool both the fridge and freezer are warm
Ice build-up inside refrigerator and cycling switch not functioning. Requires technician to take apart inside of refrigerator, clear ice and replace switch. Took my repair man about half hour to fix.
Nov 04, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerator warm but freezer is fineChanged the evaporator fan (12013211q)for BR18Ve Amana...Is it possible that the part last only a couple of years...
If your bottom freezer has ice build up, (you will see it frosted up), you do not have proper air flow. Check to see if your defrost elements are working. They are in the freezer compartment. in the evaporator. There is a defrost timer on the bottom of your fridge. You can turn the knob until the refergerator turns off, then listen in the frezzer compartment to se if the elements are working. (You will hear them sizzle)
Aug 26, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Viking freezer frost build-up
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Jul 21, 2008 | Viking DDBB363 Bottom Freezer Refrigerator
Amana refrigerator only not working
Model # important.
You have a failure of the defrost system. There are 3 components not counting wire and connectors. Most likely it is not the heater that leaves the defrost timer then the defrost thermostat. My guess is that the defrost thermostat is bad (just a guess for now) Need more info to help you more. If you know what and where the defrost timer is then advance it clockwise till you hear a distinct click, not the little clocks you hear during turning it, a distinct click. If after about 10 minutes you notice the frost down low on the freezer rear interior wall melting. Replace the Timer it is bad.
If this makes no difference then I am betting you have a bad defrost thermostat and it is located on the top right part of the freezer cooling coil behind the rear interior wall of the freezer behind the frost.
Nov 21, 2007 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
96 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
