I have an LG 8050FH front loader that gets to the spins cycle and the pump continues to run and wont go to the next part of the cycle. I have replaced the main board and it does the same thing, any ideas ???
    Guru:
  • 1,894 Answers
Make sure the lid is closed. There is a switch inside that completes the connection. Your washer may not spin or agitate if this connection is not completed. Make sure that the speed selector switch is not between speeds. Verify that the washer is not in a soak cycle. You can also reset the water level up or down to make sure that the water level control switch isn't stuck. If you hear a humming sound when the washer is full of water, you may have something stuck in the drain pump.
If one of these is not the problem, check the belt. The main drive motor has two distinct functions. The first function is to spin the basket; the second function is to reciprocate your agitator. Inside your washer's transmission is a crank type gear and connecting rods that are used to agitate the washer, with the spinning coming from the washer motor itself. This usually entails some sort of clutch mechanism. Some things to check if your washer is not agitating and/or spinning are:
If you notice weak or no agitation, the splines connecting the agitator to the drive shaft may be stripped and need to be replaced.
After a lot of use, belts can become worn or damaged. Replace any worn or damaged belts immediately. If you have a broken belt, replace it and check the pulley to make sure it's not seized.
Sometimes the drive pulley can wear out and it won't turn the drive belt. Look for wear marks, pits, or uneven spots. It's best to just replace it with a new pulley.
Many washers use a reversing motor. Sometimes it will continue to work in one direction even if it won't spin in the other direction. If your washer has a drive motor issue, you probably need to replace the motor with a new one. Call a professional appliance repair person to verify this first.
The lid switch is a safety device that's there to protect you from sticking your hands into a spinning washer. If this switch goes bad, the washer will not work. You will have to replace it. It is inside the main housing for the washer, and located near the door frame.
The coupler connects the motor to the transmission. After lengthy use, this plastic and rubber coupler can wear out. If this happens, you need to replace it.
Transmission and clutch assemblies can cause agitator and spinning problems They are fairly complex, so if you suspect you have transmission or clutch issues it's probably in your best interest to call a professional appliance repair person.
Posted on Aug 08, 2008
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Lg front loader wd-8050fh door wont lock
Hi just read your posting.Sounds like the door lock switch is faulty.Do you get any error codes on the display?Check the door latch that is attached to the door.It is the little hook that latches into the door lock switch.The tension on the hook should be quite firm.Please reply with answers to the question and the condition of the door latch.Looking forward to your reply.
Jul 14, 2012 | LG Washing Machines
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Something is stuck in our LG front loader washing machine so the water wont empty in the spin cycle
There should be two screws under the front lower panel. Remove the two screws and remove the lower panel. You should be able to access the pump from here.
Inscrew the cover on the front of the pump and clean.
Dec 31, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Front loader wm2277hs washer with OE error sign
The LG error code OE simply means “the pump is blocked”.
Presumably the water isn’t being emptied properly.
As with all error codes it is possible that there is a cause other than the exact description in the error code explanation.
And from your original post, I see that you have checked the drain pipe and the pump filter..
Those are the only 2 things I would of asked you to check aswell.
As for the price, I cannot answer that as most manufacturers wont publish their prices unfortunatly.
Sorry I couldnt of offered more help.
Mike
Jun 10, 2009 | LG Washing Machines
Spin cycle not running through stopping at different times eg 5mi
Front loader? Check out your filter & pump for blocks. Belt should be sufficiently tight, play of max half inch. And then check your motor brushes for wear. Power off the wall mains of course.
From the section i am answering this i dont have exact details of machine, but minimum is sufficient. Thats why i ask front loader?
And rate plz............
Mar 26, 2009 | Washing Machines
LG Intellowasher cannot complete spin cycle.
Unplug power cable, remove top cover and inner panel, locate water level sensor on the right with 3 wires and a thin tube, remove the tube and puff into it until you hear water bubbling. This will clear any blockage caused by suds build up. Replace tube, covers and plug back in. It should complete cycles now.
Sep 11, 2008 | Washing Machines
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Jul 14, 2008 | Washing Machines
WD 8030 W Front Loader
the load is off balace you may need to add more clothes or stop the machine and wring the water out and try to spin again( i also have an LG and mine wont spin if ther is only one item in it
Feb 13, 2008 | LG WM1812C Front Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
