Question about Sony Handycam CCD-TRV16 Camcorder
Tape will not play...
I have not used my camcorder in quite some time...but when I attempted to load a tape, it flickers and then stops playing. I stopped the tape...removed it...reinserted the tape and it will not play. I need help because these are very special tapes that I would like to transfer to DVD.
  • bfkbfk Aug 08, 2008
    This comment is also posted by bfkbfk...
    After exiting "FixYa" I went to another forum discussing problems with the Sony CCD-TRV16 and their fix seemed to be a bit much. I tried it... Guess what? ... it worked. My camera is actually playing my tape correctly. "Hit your camera several times" Sounds crazy but it allowed me to view my tape.
    The forum is:
    http://www.pechorin.com/m/2005/06/09/cod...
After posting my request for info, I went to another forum (which I listed) and read...numerous times that when you haven't used your Camcorder for a while, mechanisms get stuck. Their advice was to actually hit your camcorder with some force several times. I thought that they could not possibly be serious. But... what did I have to lose. I hit the camcorder several times...inserted a tape and believe it or not, it played...also without any flickering.
I am so very pleased because my sister passed and the vidoe tape was of her.
I hope that this solution helps someone.
Posted on Aug 09, 2008
Play back poor now Camcorder does not record
The head is dirty or bad - insert a brand new blank tape in the camcorder and perform a record through the entire tape without stopping the process until it finishes the record all the way through - this should clean the heads. Playback a pre-recorded tape. If it plays back ok then attempt an actual record. If unsuccessful, then the heads are bad.
Nov 12, 2010 | JVC GR-DX77E Mini DV Digital Camcorder
Error message "push the reset switch"
Pull the battery out to reset it. Get a DV tape cleaner to clean out the tape deck.
That should solve both.
Aug 20, 2008 | Panasonic PV-GS300 Mini DV Digital...
My tape just quit working- it flashes an error message on my camcorder - it won't play. It has my daughters first year of life on it. Can you help me?
I think my Hi8 tape was magnatized I had 3/4 of the cassette taped I played it back once and when I went to play it back again I got a blue screen. I went to the local camera shop where we played the tape on his camera and we got intermitent static but no video. My canera is a Sony DCR-TRV260
May 19, 2010 | Samsung Hi8 MP Hi-8 Tape
Cannot playback tape on Sony DCR HC36
Have you try cleaning tape? Sometimes, it is just a dirty head. Try to clean it, see if it helps.
Jan 06, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
I have a blue screen during playback mode on my Sony DCR-HC32. I am not able to see anything I recorded. What should I do?
  1. Stop the tape.
  3. Play the tape.
  7. Play the tape.
  11. Play the tape.
Aug 06, 2009 | Sony Handycam DCR-HC32 Mini DV Digital...
I tried to clean the heads with a spray cleaner and a swab.
This is the problem your camera is wet(spray)
Try to dry the camera
Nov 12, 2008 | Sony Handycam CCD-TR87 Camcorder
Sony Analog Camcorder quit playing the tape. The motor runs, but the screen is blank
hi dear
just using a tape cleanr hi-8
after that record your video using a tape cleaner, it's about $5 usd
oke
cropp
Mar 19, 2008 | Video Cameras
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
SONY CCD-TRV138 8MM CAMCORDER
CCD-TRV138 Attempted to record or play. Not operating.
Dec 20, 2007 | Sony Handycam DCR-TRV140 Digital Camcorder
Sony Handycam CCD-TRV16 Camcorder Logo
277 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
