Question about Whirlpool GC5SHEXNS Side by Side Refrigerator
Whirpool Refrigerator Making Loud Noise
My Whirpool refrigerator is making a loud noise. It sounds like the motor is going bad.
  • 3 more comments
  • klmims71 Dec 09, 2008
    My whirlpool fridge is making some loud fan like noises as well and not sure what is going on with it. Checked the back and nothing is caught in the fan... would it be the compressor going bad? Its only 3 years old, I hope not!
  • jdcollinswor Dec 12, 2008
    Pretty much the same as the other posting.....Frig is making a loud noise. Not all the is intermittant.
  • ronalddenney Jan 11, 2009
    My refrigerator makes a loud clicking sound when I open the door. If I press the door switch, the clicking sound stops. It sounds like something interfeing with a fan running.
  • Anonymous Mar 15, 2014
    Kitchenaid refrigerator model KSRS27IHSS02 making loud noise
  • Anonymous Mar 21, 2014
    lite will not work
Pull fridge out and listen if noise is comming from compressor or not. If not, then your evaporator fan is comming into contact with the ice from the evap.coil. Basically give unit a good overnight defrost with doors open as the insulation on this fridge is good
Posted on Aug 18, 2008
I have the same problem. 3 years old fridge. Under warranty?
Posted on Aug 15, 2008
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool top-freezer refrigerator makes loud noise
Do you think it is the fan in the freezer or could it be the water valve when the icemaker is filling?
Nov 27, 2012 | Refrigerators
GE Refrigerator GSS201EPWW is making a loud noise
This is the fan motor making noise but the fan motor is probably ok. The main board supplies voltage to the motor and can cause it to make strange noises.
Feb 27, 2010 | GE GSS20IEP Side by Side Refrigerator
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
WHIRPOOL WASHER LSQ9564MQ0 Started making loud
judging by the description i would say more likely the coupler
its a three peice part that sits between the mototr and transmission, kinda like a clutch,
anyway it is easily repaired
and available on
type in your model number.....
look for motor coupler
Oct 13, 2009 | Washing Machines
Making loud noise, sounds like the fan is off balance when the compressor turns on but could this be a faulty motor instead?
It could be a motor. Make sure the blades are not hitting the shroud. Normally the motor stops working when it goes bad. I have not found one making a noise so loud it was noticeable.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Jun 26, 2009 | GE GSS20IEM Side by Side Refrigerator
Whirlpool GC5SHEXNS Side by Side Refrigerator Logo
2,399 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
