Question about SanDisk Sansa Clip MP3 Player
Data base wont finish updating
Tried shuting down and restarting still won't finish refresh
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
Gateway dx4380g-uw308 keeps restarting?
Windows 8 has a neat utility that is called "Refresh Your PC". This process does not change any of your files (documents, pics, vids, music, etc.). If you upgraded your PC from Windows 8 to Windows 8.1 and your PC has a Windows 8 recovery partition, refreshing your PC will restore Windows 8. You'll need to upgrade to Windows 8.1 after the refresh has finished.
To refresh your PC
  1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, click Settings, and then click Change PC settings.)
  2. Tap or click Update and recovery, and then tap or click Recovery.
  3. Under Refresh your PC without affecting your files, tap or click Get started.
  4. Follow the instructions on the screen.
Aug 20, 2014 | Gateway DX4380G-UW308 Small Form Factor...
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Refreshing data base
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Jun 23, 2008 | SanDisk Sansa c140 MP3 Player
Refreshing data
Reformat the player and update the firmware
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
35 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
