Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Le code I have a lg lds 5811st that is 3 years old, the le comes on after 3 minutes. any ideas? Bill
  • 2 more comments
  • larryghill Sep 17, 2008
    The problem is the dishwasher will fill up with water and set for 2-3 minutes and nothing. error code is LE. I then turn off the dishwasher and turn it back on the water will drain and then refill and nothing error code LE. The Items is almost two years old
  • Anonymous Oct 03, 2008
    I have the same LE code after 2 minutes. The machine has only been in place for less than a year and the first time I had to have it fixed the repair man said he gets more calls for LG than any other dishwasher. Next time I'll research the product instead of buying the cutest one!
  • ptmuller Oct 13, 2008
    Background info:
    04/08 unit was dead - control board was replaced, unit ok
    06/08 not filling, error code IE.
    replaced fill valve, then not draining, while replacing drain pump found obstruction to impeller - unit ok.
    New problem:
    10/08 upon starting- tub drains ok, tub fills ok, wash pump doesn't come on, then, there was a faint click every 45 sec from wash motor and 3 min later error code LE displayed.
    I checked ground fault on motor - all readings between motor leads and chassis gnd ok, motor field coil test a little unusual: 500 ohms between motor leads instead of 15 ohm spec. Nozzle arm inside tub turns freely. Took sump apart impeller turns freely. float switches and door switch all ok.
    Ran test mode - wash pump does not come on. Hooked DMM to motor leads and got "OL" when set to ac, got rising voltage to 50ish vdc then 'OL' when set to dc.
  • Truckeeite Oct 21, 2008
    I have the same problem. LE error code after 3 min. I will investigate impeller turning ease and wiring in door. Thanks for the advise.
We had this same problem about 3 months ago. I read that sometime the LE error can be casued by some melted wires inside the front door panel.
We did not find any broken wires and our motor also turned freely. We ended up replacing the motor assembly and all is fine.
Posted on Sep 10, 2008
  • 1,543 Answers
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
In your case I suspect the motor first.
Posted on Aug 27, 2008
LG Dishwasher LDS5811ST does not drain last rinse out. LE code displayed. Did the shutoff of power. Most say PCB assembly, some asy control board - ?
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Feb 24, 2015 | LG 24 in. LDS 5811ST Stainless Steel...
LE code what is it???
most of the time a le means the motor. you should call for service it may have a 5 year wnty.
Feb 25, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
I use my diswasher in two year 10 times last night i put some dishes and 5 minutes latter i have LE code I read is a motor imposible i rare use the machine
all it means is that something is jammed inside the motor unit. could be a hard item like piece of bone or hard seed that missed the filter. Or could be a spoon or something jamming the impeller arm.
If you are confident in opening the base then check the service manual for details
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Jan 21, 2010 | LG 24 in. LDS 5811ST Stainless Steel...
Lg dishwasher showing error code LE how do I fix it already checked for loose wires
Try - Disconnect the Power Supply. Wait for 30 Minutes. Again Turn ON the Dishwasher. Is that Fixed the Problem.
If not, i am afraid friend, you need to replace the Wash Motor.
LE usually Refers to Motor Locked Up. Replace Wash Motor.
I have seen many of the Dishwasher gone Bad within Few Months.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 31, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Le error code what cani do
LE is a motor error The Motor is working abnormally.
Wiring connection is OK? The Impeller of Washing Pump is locked. The rotor of Washing Motor is locked. The Blade is locked.
Check the wiring connection. Replace the cause of restriction. Replace the Washing Motor. Replace the PCB.
Aug 30, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
When I start a cycle after a few mins I get LE error code
I had a similar problem Check the wires a black wire was shorted in the door. Heat broke the insulation down. George
Mar 01, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LG Dishwasher Mode LDS5811
Try checking the wiring in the door for breaks and repair by cutting and splicing with electrical tape. This site has the Service Manual: http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Nov 17, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Le code come on
When you press start on the machine, or initiate a wash cycle, do you hear any noise such as a motor?
Nov 29, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
153 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
