Question about Whirlpool Washing Machines
Model LSQ9500LQ0. The machine will only fill with water. Will not move to the next cycle. Has a buzz sound as though there isn't a connection.
  • 5,911 Answers
You could have a drive motor that has seized up, or start capacitor failure (physically attached to the motor). This could generate the buzzing noise you hear. The motor is not cheap and is priced about $130 at repairclinic.com (item number 769). It may be wise to replace the start capacitor, first, to see if that is the problem (item number 2859) since it is much cheaper.
If you need instructions on how to replace the drive motor (or capacitor), click on this link:
http://www.fixya.com/support/r599953-replacing_drive_motor_kenmore_or
It is recommended that you check the motor coupling if you have to remove the drive motor. They become worn with age and can break. To save you from having to take the washer apart again, it is recommended that you replace it. It is listed as item number 1195967. Click on this link for instructions on how to replace:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
I'm not trying to rack up a list of parts on you here. I'm simply trying to cover all bases for you, so you can rule out all possibilities. I hope this helps you. If you require assistance in locating parts, or need further advice, please let me know.
Posted on Aug 08, 2008
Fridgeaire washer dryer stack unit. The washer side doesn't complete cycle.
check door lock switch if not water valve for cold side is not on or valve is defective buzzing sound from water valve means not opening
Jun 27, 2016 | Frigidaire Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
I have a Kenmore Heavy Duty Extra Large Capacity Plus model 110, (16512690), Serial#3808455. It will not fill. When you start the machine it will make a buzzing noise as though an electric motor is trying...
You have two water solenoid valves, one hot water and one for cold. If you switch the hot and cold water hose connections the washer may fill. If it does, the solenoid valve is defective, and you will need to order a new one and replace it. If you take off the back panel of the washer you can follow the hose to the solenoid which has wires connected to it. Did you stick a bucket under the water faucet to make sure water is actually coming out of the faucet when you turn it on?
Nov 23, 2010 | Kenmore Washing Machines
Water can't fill up
Check and clean out filter inside the connector to the washer
If that is clean
Switch the water off and then start the machine cycle , you should hear a buzzing sound from the area where the inlet hose connects to the washer
If there is no buzzing and the inlet filter is clean you need a new fill valve
Apr 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Top load washer not agitating. buzzing noise from motor
1st check pump is pumping out water/ next could be motor not running due to fault, not sure if brushes are in this motor if so check for wear, quite old so could be the motor gone...
Oct 31, 2009 | Washing Machines
It fills with water, washes, then makes a buzzing sound.
This is a failed timer mechanism. replacing this failed mech will fix your issue.
Jun 19, 2009 | Whirlpool Washing Machines
WASHER DOES NOT TURN
Sounds like the motor has frozen. Try to work the drum loose from the bottom (empty and unplugged) it just might be jammed from a pen or similar item lodged inside (someone not emptying their pockets). Since its buzzing (its the motor TRYING to move the drum) it has to be jammed from something. Rarely it could be a bearing locked up in either the drum or the motor itself though its unlikely.
Mar 21, 2009 | Washing Machines
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Does not begin cycle
The buzzing noise sounds like the water valve calling for water.. check your water suppy to washer... dont sound like its getting any water or theres a blockage kinked hose ect.
Sep 02, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
80 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
