Question about One For All URC-3300 Remote Control
Help i have a samsung tv need a code and what is the device key
    Problem Solver:
  • 7 Answers
You can find the codes at this site.
http://www.oneforall-int.com/
Posted on Sep 07, 2008
6ya staff
SOURCE:
Hi i have a skandia bw600 remote 6in1 and need codes for KOGAN TV please help
1:Press and Hold the SET key followed by the desired Device Mode key(e.g. TV ), the LED indicator will light up.
2:Release both keys..
3:Use the number keys to enter your 4-digital Device Code, the
indicator should go out immediately.
but no kogan code
Jun 22, 2016 | Televison & Video
I have a Samsung TV iamuseing a ermsom remote need codes for this remote
Search Results
    Remote Control Codes
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsAug 11, 2011 - ... all televisions. If you encounter problems, use the television's ownremote control. ... While the television is on, press and hold the TV Power button and enter the corresponding two-digit code. ... SAMSUNG ... EMERSON. 64.
    Remote Control Code List
    www.jumboremotecontrol.com/remote_control_code_list.html
    ... codes for the remote. If you do not see your device listed, you can use the codesearch feature to program the device into the remote. TV Codes TV Code List ...EMERSON ... SAMSUNG, 004,005,009,015,104,105,106,109,172. SAMSUX ...‎Guide to Programming the ... - ‎Download the Manual - ‎8 Device Learning Jumbo ...
    Remotes - Device Codes - HiFi Remote
    www.hifi-remote.com/codes-tv.shtml
    TYPE, BRAND, CODES ... TV, Emerson, 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, ... TV, Samsung, 0019, 0060, 0030, 0056, 0178, 0032.
Feb 05, 2016 | Samsung 50 in. Plasma TV
Need the set up for a samsung tv
These are the setup codes for Samsung 0030, 0060, 0178, 0702, 0812
Manual located at http://www.oneforall.com/uploads/support/8210f6981b8d184d890a27645d6c32df.pdf
PROGRAMMING DEVICE CONTROL:
1. Turn on a desired device
2. On the remote control,press a device key once (i.e., VCR/PVR,
DVD,CBL/SAT,or TV).
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer's Codes (starting on page 36) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aimthe remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next page.
NOTE: If the device does not have a POWER key, press PLAY.
6. Repeat steps 1 through 5 for each device you want to control.
May 04, 2011 | One For All URC4220 Remote Control
Hi, I have the ESPN college gameday remote and I lost the manual. Could someone please give me the code for a sylvania tv? Thank you.
Manually turn of the device the user wish to power scan (TV,PVR,DVD,VCR etc.
For more than 3 seconds press and hold the appropriate device key. The LED comes On, indicating that the remote is in programming mode.
Press and release the Power key. The LED blinks once and stays on, indication that the Remote is in power scan state.
Press CH up or CH down key repeatedly untill the device switches ON.
When the devise turn ON, press and release the SELECT key to program the remote with the new code and exit.
Mar 26, 2011 | Televison & Video
I need a code for our Samsung TV/VCR using a universal remote RCA RCRN04GR. Would greatly appreciate your help!
Hello
For Combo Devices, in many cases a single code operates both parts of the device (e.g. the TV and the VCR). In other cases you need to set up two codes. For example, one for the TV and one for the VCR. Where codes are shown below as [### ###] the first code operates the first part of the device's name, and the second code operates the second part. E.G., for a TV/VCR device, the first code operates the TV and the second code operates the VCR.
Where the code is listed as [### ###] the first is for the TV and the second is for the VCR. Otherwise just the one code operates both the TV and the VCR.
0358_0942
Nov 22, 2010 | Samsung CXJ1352 13 in. TV/VCR Combo
How do i ebter a code for a samsung tv??
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Samsung TV's are: 0060, 0702, 0030, 0178, & 0812.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Jun 25, 2010 | One For All URC-3021 Remote Control
I have a Samsung TV and a 3021 B00 one for all remote -how do I use the remote. I can't even turn the TV on with it.
SEARCHING FOR YOUR CODE If your device does not respond to the remote control after trying all codes listed for your brand, or if your brand is not listed at all, try searching for your code. NOTE: Before performing a code search for a DVD player or a VCR, turn on the device and insert the required media. For example, to search for a code for your TV: 1. On the remote control, press TV once. 2. Press and hold SET until the LED (red light) blinks twice, then release SET. 3. Enter 9 - 9 - 1.The LED will blink twice. 4. Aim the remote control at the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off (after pressing POWER). If the device does not have a Power key, you can substitute another function, such as digits 0 ~ 9 , CH, or PLAY). NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first. 5. To lock in the code, press and release SET.The LED will blink twice. 6. To search for the codes of your other devices, repeat steps 1 through 5, but substitute the appropriate device key for the device you are searching for.
If you need more help this is a useful site - http://www.hifi-remote.com/manuals/manual.shtml?URC-3021
Hope I helped Dr Reed
Apr 05, 2010 | One For All URC-3021 Remote Control
I have an older Axession Samsung 4 device remote, I need codes.
have you already found the way for that old axession?
please answer to [email protected]
thanks
Jul 16, 2009 | Samsung Axession 4 Device Universal Remote
Universal remote for Samsung Hitron
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 23, 2008 | Samsung TV Remote Control
Code for samsung tv
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3021
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Dec 24, 2007 | One For All URC-3021 Remote Control
One For All URC-3300 Remote Control Logo
24 people viewed this question
Top One For All Televison & Video Experts
Joe Negus
Joe Negus
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
