Question about Visonik V4218 Car Audio Amplifier
Smoke coming from visonik v4218
I was driving my car playing my music when my visonik v4218 amp started smoking. What should i do?
  • 1 more comment
  • jdezzyt Aug 08, 2008
    ok Thanks and how much do u think that would cost me?
  • jdezzyt Aug 09, 2008
    Thanks U've been very helpful. I have just 1 more question. How can I get a voicecoil repaired on a subwoofer
    Thanks
  • 631 Answers
Generally, smoke means the power supply FETs have failed. There may be other problems that could have caused it to fail. It will need to be repaired.
Let me know if you have any other questions.
Posted on Aug 08, 2008
  • Perry Babin Aug 08, 2008
    The cost will vary with location but you can expect between $65 and $125 depending on the amount of damage. Try to find a reputable local shop to repair it so you don't have to pay for shipping (x2).
  • Perry Babin Aug 09, 2008
    Sending it to the manufacturer is the only option to restore a car audio woofer to OEM specs. The voice coils are part of the cone assembly and those are custom manufactured for that particular speaker.
There is fire & smoke coming up the exhaust
Smoke - Joseph Auto Service
www.josephautoservice.com/faq_smoke.html
Description of problem: You notice a grayish smoke coming from the exhaust when you start your ... However, if the smoke continues after the engine is warmed up, there is a problem. ... Do not look for the problem while the fire is still burning.
images for fire & smoke coming up the exhaust
Oct 31, 2015 | Cars & Trucks
1998 gmc sierra 1500 5.0L
white smoke is a blown head gasket [white smoke burning anitfreeze]
Jun 24, 2013 | Cars & Trucks
2006 nissan car bogging & white smoke coming from ehaust
check to see if you have a milky color in your oil if so you have a cracked block if not more than likely you have a bad head gasket
Feb 16, 2013 | 2002 Nissan Sentra
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
I recently had an accident with my 1995 nissan quest & had to replace the radiator & fan & transmission coolant radiator . Now , when I start it up & drive it a little ways , it starts to...
BEST THING TO DO IS PRESSURE TEST THE RAD. THIS WILL PRODUCE THE LEAK YOU HAVE IF SMOKE IS COMING FROM ENGINE IF SMOKE IS COMING FROM TAIL PIPE. GO TO PARTS STORE BUY A HEAD TEST KIT VERY EASY TO DO. LETS MAKE SURE NO HEAD DAMAGE WAS DONE AT TIME OF ACCIDENT.
Feb 12, 2010 | 1995 Nissan Quest
My 300zx got smoke issue but im not sure.smoke come both sides when i start the car.it got little oil leak from turbos.but once engine got hot the smoke goes away.when driving it doesnt smoke.but it...
It sounds like you may need valve seals.
The oil sits in the head after the engine is cut off and leaks around the seals into the cylinder.
When you start the engine it burns the oil and sends the smoke out of the tailpipes.
It does not hurt anything much if it is not to bad.
Jun 04, 2009 | 1990 Nissan 300ZX
Smoke comes from around engine
Probably a vavle cover gasket leak, small but enought to produce oil, in or on the surface of the motor doesnt take much to a lil smoke from aa hot engine...it could be collectiing in the canals ontop of the motor where the vlave covers sit on the head? or a head gasket problem....inspect it well after you run the car for a lil while, b4 it starts to smoke
May 18, 2009 | 1986 Oldsmobile Cutlass Supreme
Visonik amp problem... amp goes in and out of protection
Check for intermittent shorts on the speaker leads.
Turn down the volume control on your head unit while operating the amp, you could be over driving the amp.
Remove Speaker leads and reset the amplifier. IF the protection LED still comes on amplifier is faulty.
Below is the link to put in a help request with the manufacture for repair.
http://www.visonikcaraudio.com/category.jhtm?cid=27
Mar 25, 2009 | Visonik V408XT 250W x 2 Car Amp Car Audio...
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Big puff of white smoke at start up after sitting for several hours.
white smoke is water
blue smoke is oil.
nest time try and smell the white smoke see if it smells sweet?
if it does its antifreeze.
and also black smoke is fuel (like a leaky injector )
hope this helps
paul
Sep 19, 2008 | 2007 Nissan Altima 3.5 Sedan
Visonik V4218 Car Audio Amplifier Logo
104 people viewed this question
Top Visonik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Joe Alexander
Joe Alexander
Jerry Umali
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
