Question about Motorola For MT1000 MTX800 MTX90010v 1200mAh NiCd Battery 2-Way Radio
Programming problem I have the software and cables to program my MT1000. When I hook everything up, it will not communicate and gives me a "serial bus 011" error. Can you tell me what I'm doing wrong????? Thanks
  • rsh1962 Aug 12, 2008
    I am using a serial cable to the RIB and another cable connects the RIB to the radio.
    This error message comes on even when the cables are disconnected.
  • rsh1962 Aug 17, 2008
    I only have one serial port. have tried using the setting COM1 and difference. I think the problem is with the software, because I get the error message even with no cable plugged into the computer.
    Thanks for all your help.
  • Motorola Master
  • 1,654 Answers
Are you using a RIB-less cable, or using a RIB (Radio Interface Box)? This error appears to have more to do with hardware than software or radio.
Posted on Aug 12, 2008
  • eradiostore
    eradiostore Aug 17, 2008
    If I understand your second post correctly, and you are getting this message with or without the radio connected. You have a cable or RIB problem.
    Just as a second thought, you might check you have the correct COM port chosen.
What do I do when I put a new pcm on my 2000 dodge trk and it started up then killed it and tried to crsnk it the asd bussed and knw all my gauges quit and says now no buss
"NO BUS" means that the communication system between the computers has stopped working ! The gauges info come's from the PCM - engine computer over the bus , serial data communication network . VSS - vehicle speed sensor , ECT - engine coolant temp sensor , oil pressure sender etc.. are inputs to the engine computer . When replacing computers , most of the time they need flash programming . Dealer only in most cases . With a J2534 programming tool . Real World Reflashing with Dave Hobbs
Nov 24, 2016 | Dodge Cars & Trucks
Where is the speedometer cable located on a 1994 buick lesabre?
There no cable its a speed sensor located on the trasmission end passager side just beside the cv joint the video is and example
Apr 06, 2015 | 1994 Buick LeSabre
I bought a new HP computer and it didnt have a serial port included in it. I purchased a secondary PCI Express card that gave me two serial ports. They are programmed in as com port 1 &2. They show...
Serial connection eh? Any reason you went with serial instead of parallel? The cards likely sell for about the same price or you could just buy a USB to parallel cable that would allow you to hook up a USB port of your computer to the parallel port on the printer.
The reason that it looks like the job disappears is likely due to the fact that the serial bus is not supporting bidirectional printing so the printer cannot acknowledge that it has received the job.
Apr 19, 2011 | HP LaserJet 5 Printer
What is the drivers
Drivers are software programs written by a device manufacturer for components (such as a sound or video card) which, when executed, enable the device to communicate with your operating system. Most components come with a driver CD that enable you to install the drivers on your hand drive per the manufacturer's instructions.
If you find this information to be helpful to you, please rate my response to you on the FixYa website.
Nov 28, 2010 | Computers & Internet
I am trying to program my motorola mt1000 radio but I am getting a error message " SERIAL BUS ACCESS ERROR 004" I need help
This error message means that there is software/hardware problem. It can be that you have not programmed it in the right way. So, an error occurred while you were programming it. It's better to reset the unit.
Feb 14, 2010 | Motorola For MT1000 MTX800 MTX90010v...
I hook up my GPS to the Com Serial Port to download maps from program and the program tells me its not connected. I'm wondering if this is a path problem with the computer to the port? How can I fix it?
What program are you using and what cables are you using? To hook mine up to my non-serial Mac, I had to get an adapter cable which needed drivers. With a PC, you need to make sure you have your settings correct. Often, the manual for the software you're using to download maps will tell you how to set it up correctly.
Oct 20, 2009 | Garmin eTrex Legend GPS Receiver
After reading programming Radio Died
Unfortunately you have a corrupted code plug. The radio will need to be serviced to clear the corruption. Or if you have a clean copy of the original programming, you can try reprogramming it. (Note: Do not use the version you had saved which led to the corruption.)
Aug 24, 2008 | Motorola For MT1000 MTX800 MTX90010v...
New Computer wont talk to machine
I had the same problem and it was never addressed by singer we finally figured out that singers software was not up to date with the new computer so i just sold my new computer and went with and older model I had Singer would not take responsibility for not having up to date software so good luck if anyone has a new computer
Jan 17, 2008 | Singer Quantum XL-6000 Computerized Sewing...
here is a link to the manual for your radio (english They do not give out the information of how to program it, only authorised technicians are permitted to do so. Here is the link to motorola customer support in Puerto Rico They should be able to tell you where you can get your radio programmed, and what programming is permitted in PR. Hope this helps :)
Mar 21, 2007 | Motorola For MT1000 MTX800 MTX90010v...
Freq lock up
If you have programming cables and SW you can program a freq. in the center of the band,in slimplex. Question, can you read this radio?
Mar 01, 2007 | Motorola MT1000 Compatible 2 Way Radio...
Radio Communications Logo
221 people viewed this question
Top Motorola Radio Communications Experts
Greg Cann
Greg Cann
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
