Question about Dishwashers
Kitchen Aid Dishwasher Model KUDJ230Y3
The bottom spinning arm will not turn and therefore our dishes are not being cleaned. We have checked everything that we can think to check to no avail. It does not appear to be blocked or clogged. We have taken it out and looked on the bottom side to see if there is anything stopping it but not results so far. HELP.....
  • 706 Answers
You can try a few things to identify the problem.. first off... when you reinstall the cleaning arm..can you manually spin it freely? No binding or anything obstructing its path? If that's OK.. then you may not be getting water into the arm from it's feed. Many dishwasher arms rotate when water pressure is present.. You can verify you have water pressure by cheating the door interlock and cycling the system .. ( be careful.. since water will jet out pretty quickly) . If you don't have water pressure to the arm, chances are you have a bad or clogged pump, pinched or clogged hose from or too the pump.. Hope that helps...
Posted on Aug 08, 2008
KUDS301VWH4 kitchen aid dishwasher
Check for food etc, left in the bottom of the washer. Also check all the jets on the spinning arms, they could be plugged with food, Clean them and the machine should work better. Keep in mind dishwashers are jutst that, dishwashers, not garbage disposals! If you wnat you dishes to come out clean, you have to put them in clean!
Aug 15, 2014 | Whirlpool Dishwashers
Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
May 19, 2010 | Dishwashers
Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Apr 08, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
I have a kitchen aid dishwasher that is not dispursing the water enough to clean. I have cleaned the entire unit with commercial cleaners and have added vinegar to the washer without dishes. And still it...
You need to remove the wash arms by turning the nut in the centre of the arm and remove,then unblock the holes that are in the arms and replace them,test if the arms now turn and you can see a differance then also check there is salt in the salt dispensor located at the bottom of the machine.
Dec 30, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Kitchen Aid KUDI01FLBL3 is not cleaning my
Most likely there is debris at the pump impeller. This model has a problem with debris and grease accumulation at the pump inlet. I have no idea how it gets past the screen but it does. Remove the transfer tube on the back wall, the lower sprayer, and screen assembly. Clean out the debris and reverse installation.
Sep 16, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Top rack of Kitchen Aid not clean
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Sep 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Dishwashers Logo
277 people viewed this question
Top Dishwashers Experts
