Welcome to FixYa.
Its easy to fold down the Quinny Buzz Jogger Stroller. I have here the manual and it also have a pictures for easy guidelines on how to fold it.
Just click here. Please refer on page 7.
Please keep this or try to print out this manual for your future reference.
Please let me know if you have any questions or if this solution was helpful.
Thank you for using FixYa.
SOURCE: Folding Quinny speedi Sx Stroller
In the middle of the underneath of the pushing handle, below where the hand brake lever is there should be a button. If there is, this is what you do.
1) put the foot brake on so the rear wheels wont turn.
2) unclip the clips on the frame that allow you to adjust the height of the pushing handle, they open up, and leave them open, like this the handle you push the buggy with should slide up and down.
3) pull this handle out to its tallest position
4) Hold the handle and press the button mentioned at the start in and hold it in
5) Then quite quickly push the handle down as though you were either pushing it to lower its pushing height, or shoving it away in a temper. It needs to be a firm and quick movement.
Ta da!! After a couple of tries it should click and fold up.
I hope this helps.
SOURCE: folding campus bebecar pushchair
on mine theres a little thing on the handle yoy have to pull back and also a push on the bottom
SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
SOURCE: How to I collase a quinny speedi sx pushchair
f the dreami carrycot or the maxi cosi car seat are attached, these will have to be removed first. Apply parking brake Release the handle bars by unclasping the silver clips on the frame. Push down handlebar to lowest height as you press in the silver button under the quinny logo on the very top of the handlebar( in the middle of the foam padding) with a downward thrusting motion. The chassis should then collapse for storing. To unfold then release the transport clip on the left hand side with the red sticker on it and unfold upwards adjust handlebar to required height and lock by closing the silver clasps either side of the frame. If you want me to do a pic/video demo let me know. HTH
SOURCE: how do i fold down my quinny buzz
Hi you need to apply the brake 1st. then stand at the front, there is 2 grey buttons either side of the seat on the 2 round bits. 1 you push down the other you slide forwards, keep hold of them & pull it downwards towards your feet. This will then fold down.
