Question about Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool washer duet--- the display is flashing f-dl and won't start it sounds like it wants to do something but won't.
  • 5,911 Answers
"Fdl" is a door latch error code. Typically this means the latch requires replacement. The following link will explain this and tell you how to replace it.
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
You can find a replacement door latch at searspartsdirect.com. Just type in your complete model number and follow the link headings on the following page. If you need assistance with identifying the correct part, let me know what you rmodel number is and I can assist you. I hope this helps you.
Posted on Aug 08, 2008
Machine won't start code dl F
The machine is not starting because the door lock fails to lock the door as what error code FdL stands for. It flashes after the door locking routine fails to lock the door after 6 attempts. Replacing the door lock/switch assembly is the only viable if no problem is seen with the wire harness connecting the assembly to the central control unit. The link below contains the detailed instructions in replacing the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Washers
Aug 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Control panel displaying DL F and not starting
The door locking routine fails to lock the door after six attempts the the error code FdL flashes to indicate a failure in the door lock and switch assembly. The only viable solution is replacing the door lock and switch assembly. Click on the link below for the instructions in replacing the door lock and switch assembly.
Replacing the Door Lock and Switch Assembly on Whirlpool Duet Front-Load Washers
Nov 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9400 Door will not latch. Washer turns on, Starts clicking then flashes dL F
Hi, DL means Door Lock Failure while F is either (F80, 82,
84, 85).....
DL flashes if the following conditions occur:
  • Door lid is not closed completely due to interference.
  • Wash media buildup is preventing the lock bolt from extending.
  • Machine/motor control detects open door lid switch when attempting to lock.
  • Machine/motor control cannot determine if door lid is in a locked state.
Oct 03, 2010 | Whirlpool GHW9400 Duet Washer
Whirlpool duet washer has error code f dl. there is a buzzing sound and the washer won't drain nor spin.
Hi there
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Ty for writing to fix ya.
Best regards Richard
Dec 08, 2009 | Whirlpool GHW9150 Duet Washer
Flashes "DL" and "F"
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
Replace failed component.
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Try everything else, like reseating the connectors, then look here:
http://adsisecurity.com/KenmoreWasher.htm
Jun 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
