How can I be able to program my proscan television model no.( P S 32 108 television ) with out a remote control? to play a DVD player I pluged the wire RED WHITE YELLOW in.The television is set on channel 3 and I tryed channel 4 also, THANK YOU, DAVID FORD
Try changing channels down lower than ch.2 and it should go to a Video channel, or Video1 or Video2, etc. One of those will be for the input where you plugged in the Red/White/Yellow cable.
Or there could just be a TV/Video button on the front of the set.
Posted on Aug 08, 2008
Looking for the AT&T uverse remote control Proscan 24" LCD combo TV/DVD
If you wish to know its programming procedure, check the sites linked here. it is difficult to type all all here by this wondow. http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Both the sites have setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 08, 2014 | Proscan 26LB30QD 26 in. LCD HDTV
I have the Proscan TV/DVD combo. The cable remote works for the TV, but NOT for the DVD player. And ever since I got cable, the Proscan remote no longer works (for tv or dvd.) Long story short, I have...
Did ever worked properly?Is it wright one for unit that you have,you can check that in your owner manual,if not I will go back to dealer and ask for replacment.
Aug 23, 2011 | Proscan 32LB30QD 32 in. LCD TV
I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Sep 09, 2009 | Proscan 32LB30QD 32 in. LCD TV
I can't program a Direct TV remote for Proscan TV
Found these codes on the website for PROSCAN. www.oncorpus.com, for youmodel television.I hope this help you with your problem. UNIVERSALREMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
May 16, 2009 | Proscan 32LA30Q Television
Proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
Feb 17, 2009 | Proscan 32LA30Q Television
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
RCA DRC230 Remote Programming
The remote for this model only works with RCA, GE and Proscan TVs.
Aug 04, 2007 | RCA DRC230N DVD Player
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
