The water is coming from the freezer
when is defrosts. the drain line is in the back wall of the freezer and may be
clogged up with ice. clean out the freezer and pour some hot water in the very
back of the freezer, this will hopefully unclog the drain. if not, then you
have to take the back wall out of the freezer to get directly to the drain
line. there should just be a couple screws holding it; it is just an aluminum
or plastic panel.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
thanks Ive defrosted the freezer today there was a huge amount of ice on the bottom, not sure where to tip the hot water you suggested did you mean in the back top vent?
