Routers
Problem for Routers
Generic problem for all Routers
Router Connectivity
By jagodard on Aug 08, 2008
My D-Link DI-514 router worked fine unitl I installed a new DSL modem (Motorola 2210). I can connect to internet fine when the computer is connect directly through the modem; however, when I connect everything through router as it was prior, I'm not able to connect to internet or wirelessly. I've tried all of the disconnected/reconnecting, waiting X number of minutes and rebooting the computer...nothing seems to work. I can see my wireless network on the my laptop; however, it still does not bring me to the internet when I connect to it. What can you suggest? Thanks in advance.
James
Comments:
Aug 11, 2008
- Icek1, Thanks a million for your help. Back up and running.
Jagodard
Best Solution
posted on Aug 10, 2008
Very Helpful)
Icek1
Rank: Master
Rating: 90%, 24 votes
It will be one of two things or both - either your computer is not setup for DHCP or your router is using the same IP address as your ISP or both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
To configure your computer to use a DHCP IP address, go to the Control panel => network connections => Properties (right click on your default connection) => double click Internet protocol (From general tab) => (a new window pops up) from the general tab ensure that "obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Was this helpful?
Yes
No
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
my wireless router is locked and i don't know how to unlock it
Answer
Ihave a microsoft MN-700 router, Which I woulf likr to connect to my internet satelite and run my... (More)
Answer
When i plug my router in and i dont have internet how do i fix this?
Answer
Using the Actiontec GT704WG as just a router with comcast's cable modem. Seem to have a... (More)
Answer
can i use a wireless router with my cricket broadband
Describe your Routers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Router Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
