Question about Thump TA1001 Car Audio Amplifier
Is that ok to do mono on Thump TA1001 - Thump TA1001 Car Audio Amplifier
    President:
  • 624 Answers
Yes, it is a bridgable amplifier, if that is what you are talking about. Look at the speaker output terminal and it should have markings on it for stereo output and it will have a line between the 2 terminals to use for bridging it. When you bridge an amplifier it is mono. There may also be a switch on the amp for stereo or bridged. Put that switch in the bridged mode. Connect one speaker to the speaker output and you have your bridged mono amplifier. If you plan on using 2 woofers, it is better and safer to use it in stereo mode with one speaker on each channel.
Let me know if you need any more help,
Dave
Posted on Aug 08, 2008
Thump and hesitation at takeoff not engine mounts
thump noise moving thru driveways is the lower control arm...
Feb 05, 2013 | 2005 Nissan Murano
My spd s has a bussing soud...I have change the cable and still the same problem
I was using a 25 foot 1/4" to XLR cable from the back of the Roland directly into the Thump. As mentioned, I tried going from the Roland to a direct box with a 1/4 cable on both ends; then out from the direct box "thru"-1/4 fitting, to the XLR connection in the Mackie Thump, with a cable that had the 1/4 on one end and the XLR on the other. Still buzzing. So for grins, I hooked an XLR to XLR cable from the Direct Box Low-Z out, to the Mackie Thump, keeping the 1/4 plug going from the Roland to the Direct box and eliminating the "thru" connection from the direct box to the Thunp, (1/4 to xlr). NO BUZZ.
There is a definite loss of signal strength, ie: everything is coming through quieter, but I can raise the volume of the Thump to FULL, with no buzz, and I can raise the volume of the Roland Module to full, and still no buzz. But there is a definite loss of overall volume, I think because I am not using the direct box properly. Hmmmm. As I understand the Direct box, the IN and THRU are supposed to be used as I was, going from the Roland module to the IN, then from the THRU to the speaker. The Low-Z outs are supposed to carry a signal to a mixer, I suppose to use a FOH PA system, or for recording purposes. Still, I have no buzz. Now...........
In looking over the cords, I suddenly realized that the 25' 1/4" to XLR could be the problem. The 1/4" plug is STEREO! Not mono. Could this be the cause of my buzz? I'm thinking I have a stereo plug, so 2 wires are involved, yet I'm using it in a mono imput in the roland. Perhaps this is creating my ground loop?
After getting a 1/4" MONO to XLR adaptor, attach it to my XLR to XLR cord, go from the back of the Roland (1/4") to the speaker directly (XLR) and see if my buzz is still gone.
The problem now becomes going from the Direct box to the speaker, since it needs to be 1/4 mono from the box, and xlr male to the speaker. I cannot locate a cable like that! So, I guess the next best solution is to get an adaptor to convert one end of the xlr/xlr cable to a 1/4 mono plug. At that point I don't think the cable would still be considered a 'balanced' line though, since it goes from 3 wire at the xlr to 2 wire at the 1/4 ts plug, right? The only other solution is to continue running out of the direct box as I am, using the Low-z out xlr connection, so I can continue to use the xlr/xlr cable.
Also there was a button on the direct box, called a PAD, for -15dB, I assume that what was causing my signal attenuation. When I pushed it in and it released, I suddenly had my volume back.
May 08, 2012 | Roland Spd-S Sampling Percussion Pad...
My ford focus 2003 has a sound in the front wheel pasenger side like this: thump, thump, thump. I install new tie rod end, inner tide rod, new tires, front and rear end alignment. ?whaat is the proble
have someone drive it while you listen from outside the car. this could be achieved in a parking lot. it could be an inner fender touching your tire when you get up to speed due to air hitting it.
Jan 28, 2012 | 2003 Ford Focus
Engine noise
Check your ground and power. crossing rca's with power? Make sure your ground is to the cars's metal frame and there is no paint between the ground screw and the cars body.
Mar 15, 2010 | Thump TA1001 Car Audio Amplifier
Unable to clean 46
Unable to Clean or Machine Error 46 means your purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET or OK
b. 0 then press SET or OK
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET or OK
b. 7 then press SET or OK
b. 3 then press SET or OK
This is to reset the purge counter. Then press stop
5. Using arrow up button look for the following:
a. 0 then press SET or OK
b. 1 then press SET or OK (To reset unit)
a. 9 then press SET or OK
b. 9 then press SET or OK (To exit Maintenance mode)
Nov 10, 2009 | Brother DCP-350C InkJet Printer
Stereo makes a thump sound after a installed a mono amplifier, the noise comes from the subs it drives, its also present when i turn it off, just a single loud thump noise.
Are you turning of the amplifier first or the source of audio? Amps should be powered down first and then the source. If both are powered down at the same time make sure the volume is down or otherwise you will always get a thump. The opposite when you power up. The source and then the amp. Hope this helps.
Oct 13, 2009 | Rockford Fosgate Punch 1000W Class BD Mono...
My subs don't bump to the beat, they just go THUMP THUMP THUMP...
It sounds like you need to ask for pro help mate, mybe the amp just needs setting properly, Is the amp on bypass for bass, or does the amp run the complete system
Jun 13, 2009 | Cadence TXA 750D High Power Mono Amplifier...
Speakers are thumping and cracking when powered up...why?
you are better off setting your deck speakers amp to a high pass filter setting on the amp. Adjust gains to increase desired bass and clarity. Turn off loud button if you have one, that will distort your deck speakers.
Feb 13, 2009 | Power Acoustik PTID-8960 Car Video Player
My Jbl mono amp cuts out
It's likely that the amp has blown output transistors. To eliminate other possible problems, read through the following page:
Amp Going into Protection Mode
Let me know if you have any other questions.
Sep 14, 2008 | JBL GTO75.4 Car Audio Amplifier
Subwoofer "thumping" w. no audio feed
You need to check your ground connection. If there is a bad ground there will be feedback to the amp and it will just sit there and loop back with the Thump, Thump, Thump sound. I had to wire my amp's ground all the way back to the negative battery terminal. It was a pain but I have never had a problem since :)
Feb 12, 2008 | JBL SCS125A System
Thump TA1001 Car Audio Amplifier Logo
152 people viewed this question
Top Thump Car Audio & Video Experts
xxxxxx xxx
Are you a Thump Car Audio and Video Expert? Answer questions, earn points and help others
