Connection of Canon Multipass C3500 to Juno DSL phone line.
I started using Juno DSL recently, and connected C3500 to the wall phone
jack as instructed and set it to FAX/TEL mode to receive fax. When I receive a phone, it also rings C3500 and I cannot talk. How can I solve this
and use phone or receive fax? DSL works fine. I connected C3500 to LINE
of my PC. My PC has Windows WP. Appreciate your help.
Mac Isomine
  • mac_iso Aug 08, 2008
    I will post again, as I wonder if you got my message. I read the
    instruction book thoroughly as I have been using this C3500
    over 8 years. It doesn't tell me how to use it when DSL is
    used. There must be some reason that I cannot use it as a
    fax machine. Please find out and let me know.
  • 2,712 Answers
Read the instructions again again...u probably got it set up wrong..
Posted on Aug 08, 2008
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
What to do if dsl light is blinking
This likely means that your DSL modem is not trained up with the DSLAM. - Geek talk for your modem is not connected to the phone company's equipment properly.
1.) Remove power from the modem
2.) Remove all devices (including the DSL modem) from all phone jacks in the house.
3.) Add the DSL line back to the wall jack, taking care to plug the wall jack into the correct jack on the DSL line. (Do not use a DSL filter on your modem!)
4.) Power up the modem/
Still not working? Continue...
5.) Try a different phone jack
6.) Try a new phone cable between the wall jack and modem
7.) Call the phone company for further assistance.
Dec 18, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Canon MP730 will not fax. Sounds funny at the start like it is double dialing
Check that the "Alarm" light is off. If it is on, and remains on after a power cycle (off then on), you need to call tech support.
Otherwise, verify the line settings (User Manual, page 6-4). You probably have tone dialing and not rotary dialing. Verify that the "L" and "Phone" jack are connected correctly to the wall socket and (optionally) to other equipment such as phone or answering machine.
Also, verify that the phone line is a POTS compatible line, i.e., not an ADSL socket (or, if it is, it has the proper filters installed) by plugging the cable into an "old" telephone and verifying the line tone comes up and dialing works.
Nov 30, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
My new LevelOne WBR 3600B router does not eyncronize
Hi, If you are using dsl line, then try to add SPLITTER or FILTER between wall jack and phone.
When you connect splitter you will have one input line and two output line, one is called voice which you connect to phone and the other is data which you connect to router.
you can use LAN cable to connect modem and computer. before you set the connection please remove all the connection from wall jack to computer, wait for 2 mins and then re connect, like this it will remove if any static charges stored. If you are able to see the DSL light is up and no more blinking, Then your problem is solved. Hope this information will help you
Nov 17, 2009 | Computers & Internet
Need a manual for canon multipass c3500
You can download manual here
Sep 04, 2009 | Canon MultiPASS C3500 All-In-One InkJet...
How to connect the telephone lines
Please let the fax line be connected to computer itself do not remove , In the DSL line you get a splitter which the lines for phone and ADSL modem connect the splitter to DSL Line and from the Splitter you 2 o/p ports with phone marking or symbol connect the phone line to it and to line port connect the main 8957and then to ADSL line to ADSL modem from the ADSL modem connect to lan port which is behind the computer (not to dial up modem
i.e is fax line ) or the usb port in the computer ...
Good luck...
Feb 02, 2009 | RCA 25201RE1 Corded Phone
Using a ppoe connection to a DI-524 is it necessary to put a modem in line?
DSL connection:
Computer -> Router(Dlink) -> DSL Modem -> Telephone wall jack/outlet
Computer -> DSL Modem -> Telephone wall jack/outlet
PPPOE = using a username/password combination to authenticate the connection to the ISP.
Nov 04, 2008 | Computers & Internet
Lexmark x6150 unalbe to fax phone line is active using dsl
Hey Tony - Did you recently hook this up to the DSL for the first time? This unit is supposedly not able to work with a DSL line.
The fax modem in your AIO is an analog device and cannot be used on an ISDN, DSL, or PBX digital phone service. However, you can connect certain devices to your AIO that let you use the fax function in addition to these digital phone services.
To connect without an unsupported line:
Connect an active telephone cable from the AIO to the telephone wall jack.
To connect with an unsupported line:
If you use an ISDN phone service, you can connect to an analog telephone port (an R-interface port) on an ISDN terminal adapter.
For more help and to request an R-interface port, contact the ISDN provider.
If you use a DSL (Digital Subscriber Line) phone service, you can connect to a DSL filter or router that will allow for some analog (rather than digital) use.
If you use a PBX phone service, you can install an analog phone line for a fax machine.
If this was working on the DSL let me know. I don't know the location but obviously a separate phone jack is the easiest. Let me know. If this helps you fix it you can rate this as fixed. If you are just going to rate this as helpful I'd rather you please not rate it and just add a comment and say thanks for the info.
If you need more help just add a comment and I'll be glad to assist you further. Thanks.
May 09, 2008 | Computers & Internet
Westell 327 wireless router
you have the DSL filters plugged into all your telephones, but NOT plugged into the DSL modem?
is the DSL modem configured to automatically connect using your username and password?
have you tried using a different phone cable, or plugging into a different phone jack?
Mar 29, 2008 | Westell Wirespeed VersaLink...
109 people viewed this question
