Question about Compaq Presario 5440 (152507-004) PC Desktop
Adding memory what section of the bios do i get into to add more ram?
  • 170 Answers
You shouldn't,t have to go into bios at all. Shut the computer off, install the ram, turn on computer. The bios will see the memory automatically.
Posted on Feb 08, 2009
SOURCE:
T6524 won't recognize all ram
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Feb 24, 2013 | eMachines T6524 PC Desktop
Acer Aspire M3400 Desktop PC. Memory Upgrade Issue
please check the memory timing settings. if your mixing up ram they may not have the same memory timings and require you to go either higher or to the supported settings that either memory can use. for example if corsair runs at 8-8-8-14 and kingston runs at 10-10-10-16 then you will need to bump the settings to 10-10-10-16 since the computer is trying to set the timings for kingston to 8-8-8-14 which it does not support.
Feb 18, 2012 | Acer Aspire M3400 PC Desktop
Vostro 200 4 mem slot 512 in 1 and 2. added 1g to 3 and 4. sys info 3 gig installed 1 g avail. Reset csmos...no change. any ideas????
On this model specs it says it will support up to 4 G of memory on DDR2 up to 800 mhz ...be sure the one you added are no larger than 1 G ..and not exceed 800 mhz ...and if the one you had is on 667 mhz ..you will have to get into bios setting and also set the ones on 800 to be read on 667 mhz ...It should be done that auto ...but for some reason it seams it does not..Anyway ..get into Bios ..and first thing ...try to engageg the optimal factory defaults...(it will be a link ..on the bottom and indicate which function key to press and confirm for that ) ..and also press F10 to save changes and restart ...
After that ..boot it up ..and see if the memory is read proper..to check that go just right click on my computer ..and properties..ad will be there..
Also ..if your video card ..has no memory of it own ..it may take some from the ram ...and the more ram memory you add..the more will get ..if it is capable ....I encoutred computers that were able to get up to 1024 M from the ram memory and use it for the video card .when the ram memory was more than enough ..
Another thing may be the incompatibility ..so ...try to see if the new added one ...the 2 x 1g ...left alone in the slots ..will work ..and be read entirely ..If this is the case ...use just these 2..and get rid of the old ones...The difference in the frequency ..may be to blame ..
Another thing you may do ...is to reinstall the operation system from scratch ...or restore it using the recovery disk or partition .,.if you have such a thing ..and if it contain the operation system as well ...
This will force the memory to be read a a common frequency ..and make it functional if they are new and functional ..
Oct 05, 2011 | Dell Vostro 200 PC Desktop
I have an Acer am5100-u5301a. Is there a bios upgrade?
If the specs read that you can operate with 4GB of RAM, then I believe the AMD690g chipset is not the culprit.
The RAM that you're adding may be defective, or incompatible with the existing RAM.
Another possibility could be a bad RAM socket.
I also doubt you would get a black screen due to adding more RAM than the system is capable of handling, it would still start, but would not utilize the additional RAM.
Black screen usually means bad RAM or incompatible RAM or bad socket
Nov 02, 2009 | Acer Aspire M5100 AM5100-U5313A AMD...
I have windows xp 64bit and iam trying to use 2 slots of 2gb memory ddr2 and instead of 4gb memory iam getting as a result 2.43gb how can i solve this? i have an asus pb5
It looks a little low - but two possiblilites... the motherboard's chipset does not support more than 3GB of ram or you have not configured your ram correctly in your BIOS setup.
Restart computer and press whichever key it asks you to so you can go to Setup or BIOS config.
Look in the memory section, advanced chip set section or if necessary just go through all the options until you see the map memory hole... this allows the BIOS to see more memory.
But I think you will find it is your chipset. You could try flashing the BIOS to the latest version --- but that's another story.
Oct 02, 2009 | Microsoft Windows XP Professional SP2C for...
Added more ram but it's not working Compaq E500
what did you mean not working ?? didnt see the new Ram memory ?/ or didnt boot at all ....anyway ...when adding new ram memory ..first thing you do is to remove the Bios battery for to let bios on defaults and let it be able to read the new added unit ....second ...be sure the new added ram is compatible and in the same frequency ,then remove the battery like I said and in the last ...reinstall the operating system ....always look at the boot to see if the ram memory that is displayed is the same value with the one you know that actually is installed on the slots...it should work if this was just an option to make it faster ...and not a wild guess cause it use to have issues and didnt boot before...
Sep 10, 2009 | Compaq Armada E500 Notebook
I added more memory to my vista
Has the BIOS detected the additional memory or it has stayed the same?
Is the new RAM the same make as the other RAM module and speed?
To determine if the new RAM is OK, remove both RAM modules and insert only the new RAM module and see if the laptop boots up.
If it doesn't boot up then the RAM module is either faulty or incompatible with your laptop.
If it boots up then insert the other RAM module in the second memory slot. Check the BIOS to see if the RAM has increased. If not then the RAM modules are incompatible with each other. I suggest you look at the make of the original RAM module and purchase the second one from the same manufacturer.
Aug 26, 2009 | Dell Computers & Internet
Adding ram do I need BIOS update see detailed question
I don't think that this will work! I think 512 is the maximum for it. May be it'll just improve speed a little but it's always risky to update BIOS on older PCs. And this 512 sticks will cost you a lot. I think you better think to buy a new PC. Good Luck!
Apr 17, 2009 | Compaq Presario 7588 PC Desktop
Can't Install RAM in DDR2 and DDR3 DIMM slots
You cannot use DDR and DDR2 ram at the same time, because its always been like that (ie, no SD and DDR, or SD and RIMM)
What you should do is switch to all DDR2 sticks.
Jan 09, 2008 | Gigabyte GA-8PE667 Ultra Motherboard
PC turns on then quickly turns off
Does it boot fine if you remove the memory you just added? If it does then try switching the memory that was in it before with the memory you just added. You want to first determine if the ram you bought is bad or incompatible.
Dec 06, 2007 | Computers & Internet
Open Questions:
Mozilla Thunderbird Tech Support pHoNe%[+l84424O9l11}]^:~%NumbER USAjsery Mozilla Thunderbird TeCh SuPpOrT Number +[184424O9l11}]USALogin Mozilla Thunderbird customer service phone Number Repair service center to resolve all Mozilla Thunderbird products. Mozilla Thunderbird is an American multinational company which was founded by Michael Mozilla Thunderbird using its company headquarters in Round Rock, United States of America. Contact Mozilla Thunderbird for Setup & Installation Mozilla Thunderbird Setup Free & Installation Mozilla Thunderbird TECH FREE number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Mozilla Thunderbird Connect, Mozilla Thunderbird TECH Free Phone Number you'll be searching out Mozilla Thunderbird Connect setup as well. So, here we're with all cthe setup process and for your to Mozilla Thunderbird Connect. Get Mozilla Thunderbird Setup Instant Free Mozilla Thunderbird TECH FREE Phone Number Usually, the setup TECHnique takes a number of time. One TECHnique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may locate the approaches simplified tdako help you even if you aren't TECH-savvy. Let us undergo the method of Mozilla Thunderbird Connect setup for Windows and for Mac. So, right here we go vikki TALATUMAS
Oct 21, 2019 | Mozilla Computers & Internet
WISCONSIN 1=855=536=5666*$+ Crypto support number Crypto assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Crypto helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. CryptoTeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... CryptoTech Support Phone Number +{1-855*536*5666*} to resolve all Crypto products. is an American multinational company which was founded by Michael Cryptousing its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Crypto is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .CryptoCUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL CryptoCUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. CryptoCUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Cryptois an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Crypto tech support pHoNe {18555365-666-}} nUmBeR USA Crypto tech support pHoNe Number {18555365-666-} to resolve all Crypto products. Crypto an American multinational company which was founded by Michael [email protected] Printerusing its company headquarters in Round Rock, United States of America. Crypto Support Phone Number for Crypto Technical support help. Crypto Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
Oct 21, 2019 | Epson Computers & Internet
PREMIUM+{1-855*536*5666*}Crypto phone Number Crypto assistance available 24*7. If you are facing any issues in printer you will get expert assistance through Crypto helpline number {+1855.536.56*66*}for fixing all kind of printer related issues within seconds. CryptoTeCh SuPpOrT pHoNe #{1855.536~5666*} nUmBeR USA... CryptoTech Support Phone Number +{1-855*536*5666*} to resolve all Crypto products. is an American multinational company which was founded by Michael Cryptousing its company headquarters in Round Rock, United States of America. SPOTIFY tech support pHoNe Number {18555365-666-} to resolve all SPOTIFY products. Crypto is an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Tech support Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY tech support number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and services. {1*855.536.5666T~} allows to any type of help is provided of experience employees .CryptoCUsToMer cArE {1*855.536.5666I~} nUmBeR USA OFFICIAL CryptoCUsToMer cArE Number {1*855.536.5666-} to resolve all OFFICIAL products. CryptoCUsToMer cArE is an American multinational company which was founded by Michael OFFICIAL using its company headquarters in Round Rock, United States of America. SPOTIFY toll free pHoNe Number {1855536,5666-} to resolve all SPOTIFY products. Cryptois an American multinational company which was founded by Michael SPOTIFY using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, Cryptocare number, and selling of computer-related services and products. SPOTIFY Toll free Phone Number Recently, SPOTIFY has been named the number SPOTIFY customer nical care advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, SPOTIFY toll free number can be dialed to contact the certified customer nicians Contact Customer nical Care Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a SPOTIFY Service Tag or a SPOTIFY Get SPOTIFY Customer nical Care Phone Number and Customer Services. SPOTIFY is a US-based multinational customer organization having its headquarters located in Round Rock, Texas. This customer organization cares, repairs, sells, and develops customer nology products. Basically, the company offers computer related products and vikki services. Crypto tech support pHoNe {18555365-666-}} nUmBeR USA Crypto tech support pHoNe Number {18555365-666-} to resolve all Crypto products. Crypto an American multinational company which was founded by Michael [email protected] Printerusing its company headquarters in Round Rock, United States of America. Crypto Support Phone Number for Crypto Technical support help. Crypto Support is an independent body, which is established with the vision to deliver exceptional technical service for the Epson brands.
See all Compaq Presario 5440 (152507-004) PC Desktop Questions
Compaq Presario 5440 (152507-004) PC Desktop Logo
47 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
