Question about IBM ThinkPad T30 2366 Notebook
Start up problem
When I start up my Thinkpad, it goes to the IBM logo, then after about 20 seconds it will go to a black screen and a message that says: PXE-E61: media test failure; PXE-M0F:Exiting Intel boot agent; Operating system not found. Can I use the Disk-to-Disk recovery? If so, how do I do that? If a Disk-to-Disk recovery won't work, will a recovery disk work? I have Windows XP. Thank you.
    Genius:
  • 2,028 Answers
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Posted on Aug 08, 2008
dugiehowsa
  • 114 Answers
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
Posted on Oct 10, 2006
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF  found no fault on the HDD. (full test took 45minutes)    Give it a try.  I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives.  Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck.
Bryan
Posted on Oct 21, 2007
  • 15 Answers
SOURCE: Acer 4520 laptop media test failure
Your hardirve is damaged or your partition is corupted to fix this problem reinstall windows and make a new paetition or check inside your computer to see if a cable from the hardrive is desconnected.
Posted on Jan 17, 2009
Geekman
  • 32281 Answers
SOURCE: my acer 7520 opens with an error reading NVIDIA
This error message could be a faulty hard disk or a faulty disk controller.
Reseat the hard disk to see if the problem is fixed.
If not go into the BIOS settings and check if the BIOS can detect the hard disk.
If the hard disk is not detected then remove the hard disk and connect it to an USB hard disk adapter and connect it to a working computer's USB port. If the this computer cannot detect it as an external hard drive then the hard drive is faulty. Then the Acer needs a replacement hard disk and Windows installed together with the laptop's device drivers and programs etc.
Posted on Oct 20, 2009
  • 3940 Answers
SOURCE: PXE-E61 : media test failure,
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Posted on Jun 17, 2011
Laptop turns on, goes to first screen which reads IBM TRHINKPAD. THEN FLASHES OFF TO NEXT SCREEN WHICH READS THE WINDOWS XP LOGO then it goes black and doesnt come back on
Your installation of Windows is most probably corrupted. Try pressing and holding the F8 button on your keyboard when the 'IBM THINKPAD" screen disappears. That should bring you to a Windows menu where you can select various modes. Select Safe Mode and press enter. If it boots, then you know that something's wrong with Windows and not the notebook itself. What have you installed prior to this problem? Maybe you should try uninstalling it while in safe mode, and then try starting up Windows normally again.
If your windows doesn't start anyway, you should get some live OS (OS that can boot from CD) like Ubuntu or Puppy Linux, so you can save the data from C: partition (burn it or copy it elsewhere) and then reinstall your copy of Windows XP.
Sep 01, 2011 | IBM ThinkPad R32 2658 Notebook
Ibm thinkpad t30 how to get it to enter safe mode
Turn the computer off Turn the computer on Immediately hit F8 several times a second until a black and white menu appears, if you get the windows splash, you missed it. Start over Select which way you want windows to start in safe mode You will get a lot of white messages on a black screen You will then get a message that says proceed to safe mode or do a system restore to recover Proceed to safe mode.
If this answers your question, I'd appreciate 4 thumbs up as I do this for fun.
Nov 20, 2010 | Computers & Internet
Today when I was using my IBM Thinkpad R51 the screen went black and the machine shut itself down. It restarted normally but after about 20 minutes did the same thing. I never got a warning or any kind...
your battery could be failing,thats the most obvious thing.Then you might have accidentaly set the sleep mode,if you have this facility in your software(most pc's do).you must just search through your soft to see if you have enabled this function--good luck!
Davey Snake!
Oct 24, 2010 | IBM ThinkPad R51 Notebook
My A30 ibm laptop wont start up??
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Mar 03, 2010 | IBM ThinkPad A30 2652 Notebook
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
My think pad goes dark after the windows logo...
Right click on te screen and click on properity in the screensaver tab check the power setting to make sure it is not set to hibernate if so un check the boxs and check the shutdown time
Apr 21, 2009 | IBM ThinkPad T20 2647 Notebook
How do I put new windows on the thinkpad I have got the cd
this is sometimes due to the boot sequence. identify the key to press so that you can access its bios at start up. a shot message is usually displayed for a short time at start up.
please go to the bios and change the boot sequence to start from HDD.
Dec 18, 2008 | IBM ThinkPad 600E 2645 Notebook
IBM ThinkPad R52 Screen fades to black
Try using a flashlight at different angles and let me know if you can see a faint image of the desktop If so It is your inverter board that needs replaced.
http://www.google.com/products?q=IBM+ThinkPad+R52+inverter&ie=utf-8&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&sa=X&oi=product_result_group&resnum=1&ct=title
Sep 18, 2008 | IBM ThinkPad T23 Notebook
IBM THINKPAD
Hi...there,
It's seems your Thinkpad need a new inverter, due to a backlight inverter burnt out. Get a new one or repaired it. Good lucks!
Sep 06, 2008 | IBM ThinkVision L170 17" LCD Monitor
Won't start up!!!
its a hard disk problem.. backup your important files then reformat it... or try to reinstall your os..
Apr 14, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
343 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
