Question about AT&T LG CU515 Cell Phone - Black
LG CU 515 connectnig and disconnectnig bluetooth device
I just bought a LG CU 515 and it keep connecting and disconnecting from the blue tooth device. I tried different bluetooth devices and the same thing happens.
any suggestions?
    Brigadier General:
  • 7,752 Answers
You may need to try master resetting the mobile and clearing all paired devices then try again
Posted on Oct 14, 2008
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I just bought a samsung soltice phone and I have a scala-600 bluetooth but I cant seem to get them to connect have any suggestions and I have used a bluetooth befor.
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 12, 2010 | Cell Phones
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
Bluetooth will not stay connected on my 2006 BMW z4
Depending how far of a range your getting, between your razr and your blue-tooth is important. Any range of 30ft or over is less likely to connect/search/and or pair with any capable blue-tooth device.
Try pair the two devices again, but remember to save the trusted blue-tooth to your device so that disconnection can be prevented only by your command.
If your blue-tooth has a short, or battery is extremely low then that TOO can cause disconnection.
Hope this information can be of a benefit to you. Thanks.
Mar 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
I have a lg cu 920 how can i blue tooth songs from my phone
you have to be so close to a person to be able to send them something. if you hit search new device under your bluetooth menu it will show the people with their bluetooth on around you.
Jan 31, 2009 | LG Vu CU920 Cellular Phone
How do I disconnect my phone from another Blue Tooth device?
Go to active devices menu in the bluetooth menu and delete any devices listed there and start find new device ... it should work fine ...
Oct 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
BLUETOOTH
why wont my LG RUMOR blue tooth receive files from other phones
Jul 02, 2008 | LG RUMOR Cellular Phone
Blue Tooth Connection for LG Shine
I have been having the same problem with my 720 trying to reconnect to a bluetooth. I have purchased a Plantronics 220 and also a Motorola one. My phone will connect one time, and shortly after my test call, it will disconnect on its own, and I cannot get it connected back. I thought it was the bluetooths messing up but actually it is my phone. I have contacted LG about this problem and they told me I would have to send my phone back so they can take a look at it. So you may want to call them and put in Another Complaint.
Jun 18, 2008 | Cell Phones
5400 won't connect to blue tooth device
Change the bluetooth device.
May 18, 2008 | Cell Phones
AT&T LG CU515 Cell Phone - Black Logo
156 people viewed this question
Top AT&T Cell Phones Experts
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
