Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Powder detergent clumps in the detergent tray. I ran it on rinse only to try to clear it all out, but that didn't work. I cleaned it out manually and added just alittle powder detergent, but the same thing happened. In addition, the silverware below the detergent tray have powder residue--any suggestions?
Most detergents disolve better when water temperature is above 120 degrees.
Posted on Aug 25, 2008
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
Hi I own a Defy Automaid 600 and has never used fabric softener before. How do I go about
It's very easy- you pour it into the conditioner tray before you start the washer- like the detergent/powder- and (normally) the washer directs water into the softener tray on the (final) rinse.
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash (pre-wash detergent) and see where the water runs in, then advance to the main wash (main wash detergent) and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 05, 2011 | General Washing Machines
The washing powder is still in the dispenser at the end of the full wash??
See if the water is actually running into the washing powder tray by using these guidance notes (written for another problem!).
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash and see where the water runs in, then advance to the main wash and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
Now if the water is NOT pouring into the washing powder tray an engineer call is required ;-0(
Good luck,
John C
Mar 29, 2011 | Whirlpool AWOE8748 Front Load Washer
Dishwasher detergent clumps in pre-wash and main wash compartments
Make certain that there are no apparent obstructions between water and detergent. If no obstructions and the detergent dispenser and spray arms are operable, then the detergent should dissolve during wash. Otherwise, try using a different kind and amount of detergent (e.g.: powder vs. gel or gel vs. powder, and less detergent). If still clumping, contact an appliance service company.
Feb 20, 2010 | Maytag Dishwashers
Powder detergent not distributing in ge quiet power 3 dishwasher
Try storing your powder in the dryer cupboard or in a warm area
It is more than likely that it is damp when it is going into the machine which means it clumps up instead of mixing with the inflow of water
Other thing to check is is there is a restriction at the back of the dispenser drawer which is not allowing the powder to flush down into the machine.
Finally , dry the dispenser slots with kitchen roll and give them a spray with a good quality furniture polish, allow it to dry for a few minutes and then buff it with a cloth, the silicone or wax in the polish should help the powder to slide
Jun 02, 2009 | General Electric Adora GHDA670N Built-in...
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Detergent will not dispense
generaly the detergent tray has a "gate" that needs to be moved to the top position for powder. (up for powder, down for liquid). This is the generic answer. if you verify the model number or list the model of your unit I will attempt to locate a users guide for you.
Please take the time to give this solution a fix ya rating
clarkco
Mar 07, 2009 | GE WSXH208A Front Load Washer
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Water leaking through soap dispenser drawer
OLDFIXER was exactly right ! I had water gushing out of my LIQUID detergent tray. I removed the tray by pushing down on the flexible tab at the back of the tray and when I had the tray out I discovered A LARGE AMOUNT OF DAMP powder detergent caked up on the inside. I removed it all and sprayed some hot water inside AND ITS COMPLETELY FIXED !!! GOD BLESS OLD FIXER.
Apr 27, 2008 | GE WSXH208A Front Load Washer
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
428 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
