Question about GE JGBP28 Gas Kitchen Range
Ge gas oven
My gas oven wont come on where the gas comes out at the bottom, the flames wont ignite can you help me asap
  • 1 more comment
  • shawn51 Jan 21, 2009
    the burners light and work well..just can't get oven to come on
  • gmaggio May 09, 2009
    The oven burner ignition loop is experiencing a current drop-off which I have isolated to the gas control valve electrical connection. Do I need to change out the gas control valve?
  • Anonymous Mar 30, 2014
    top oven ignites but flame wont go higher when you turn it up
    Sergeant:
  • 409 Answers
Is it just the oven or the burners as well?
Posted on Sep 13, 2008
Ge gas oven ignites but flame does not come on to heat oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 10, 2011 | GE Ovens
JGB900 oven won't work. Range top works, broiler works. No glow in oven. Regulator is on.
Your problem is with the oven ignitor. Remove the racks from the oven, remove bottom shelf. Remove the metal plate covering flame spreader. The igniter should now be visible. Turn oven on and watch the glow from the igniter. It will come on but it wouldnt get too bright, so it wouldnt open the gas valve. After changing the ignitor, oven should light.
Feb 17, 2011 | GE Profile JGB900 Gas Kitchen Range
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven doesn't come on-but the self clean and broiler work
Check the electronic starter/pilot ignition on the bottom oven burner. It may be dirty, too far away from the pilot gas or the temp sensor on the pilot light flame may need replacing.
Dec 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My pilot light wont light and my oven will not come on the gas top burners are fine how do i fix this problem
Later model ovens don't usually have an actual pilot light in the form of a flame. It is usually some type of a spark or heated coil ignition system. It is usually located under the flame spreader and bottom plate in the oven. It is a safety system to keep gas from collecting in your home. You can remove the oven bottom and see the mechanism close by to the gas inlet tube. When you turn the gas on, you should be able to see either a small spark or bright red coil. A replacement can be purchased and installed, but it is probably a job for a technician.
Nov 13, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra Oven flames TOO High
have your gas pressure regulator checked
Nov 02, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
GE Spectra TrueTemp Oven Pilot is Out
REmove bottom panel from stove. shut gas off for at LEAST 5 min. Longer is better. Then placel open flame above gas nozzle, slowly turn to ignite posiiton. After it is lit, wait 30 seconds and turn to on positon.
If by chance this model doens't have a knob for this, then turn gas valve off for 5 min, let fumes evaporate, light flame, place over nozzle, turn gas on.replace bottom oven panel slowly.
Jan 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Creda convection oven wont heat up
my ge profile double electric oven, bottome convection wont heat up
Feb 19, 2008 | Ovens
GE JGBP28 Gas Kitchen Range Logo
145 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
