Question about Mitsubishi WS-65869 65" Rear Projection Television
MITSUBISHI 65" RAER PROJECTION TV MODEL-WS 65511
My Tv does not power on. When i turn it on, the green light comes on for a couple of seconds and it shuts off..
pl help
  • 4 more comments
  • hima rao Aug 08, 2008
    Try to press both the menu button and the input/device button on the
    set both in together and hold in for 6 seconds to see if the led will
    blink a two digit blink code, then let me know the two didgit code, and
    I will try to assist you.
    i did the above
    blinks twice rapidly, then pause, then does the same ten times
  • hima rao Sep 22, 2008
    new problem
    Thank you so much for the helpful solution to the convergence problem. The TV worked well for some time, we now have a new problem. The blue convergence adjustment is showing curved lines.
    Can you please help?
    Thank you
  • 06Busa Sep 30, 2008
    I have the4 VS-60705 with same problem. I pulled the code. It looks like 22. 2 rapid flash, small pause, 2 more fast. Bigger pause and repeats. Is it suppost to reapet?
    And if 22 is correct what do I need to do?
  • ctclock Apr 16, 2009
    blinks code 12 set has convergence problem
    blinks code 12 set also has convergence problem gftime@gmail.com
  • Mitsubishi Master
  • 8,617 Answers
Try to press both the menu button and the input/device button on the set both in together and hold in for 6 seconds to see if the led will blink a two digit blink code, then let me know the two didgit code, and I will try to assist you. Please respond to this same post when replying.
Posted on Aug 08, 2008
  • Sonny Berry
    Sonny Berry Aug 08, 2008
    If you look on the center circuit board you will need to locate two Pico fuses they are green and are identified by their numbers F9A04 and F9A05 unsolder one end of those two fuses and see if they are open, No resistance. If they are you will need to replace the STK393-110 Convergence IC and those two picos, and your set will be repaired. I have seen that to be the problem in 95% of that model when blinking the two digit code. You can get the two 5Amp pico fuses and the STK393-110 convergence IC and they provide free instalation instructions. I will also include a picture of what the two pico fuses look like in case you dont know. Heres the link for the parts
    http://servicemanuals.vstore.ca/
    and here is what the picos look like.
  • Sonny Berry
    Sonny Berry Sep 22, 2008
    double check the solder on the ICs thats most likely the problem.
Mitsubishi WS-65511. Won't stay on.
Bad filters in the main microprocessor. good luck.
Aug 30, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Stays on for 2 seconds and switches off
A 2-2 code on that unit means over current shutdown. 95% of the time that code indicates defective convergence output IC's.
Jun 09, 2009 | Mitsubishi WS-65869 65" Rear Projection...
My Mitsu WS-65511 will not power on. When power is pressed on tv or on remove solid green light comes on for a moment as if television is going to come on and then it just shuts back off. I have tried...
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25.
Apr 05, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsubishi WS-65511 won't turn on.
Feb 22, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Help on Mitsubishi WS- 65513 65 in.
Look around online and find that this is a huge problem with Mitsubishi rear projection tv's. It is the board that needs replacing at $1100. My tv is 3 years old and already a big paperweight. Blinking green light of death.
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi will not turn on
If the green light flashes, thats an indication that there is a problem in the sweep power supply or the horizontal drive circuit. Its not a problem a layman or unexperienced person should attempt to repair unless you know about electronic circuits and how they work.
Sep 22, 2006 | Mitsubishi WS-65511 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
998 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
